monkboughtlunch
Super Member
What do folks use to restore tarnished brass knob covers on their Fisher 400,500B/C,800B/C series tube receivers? Is brasso a good choice?
A couple of days in vinegar water followed by 600 grit sandpaper and wire brush. Might want to remove the metal spring from inside before soaking.
1409
1411
Did you pry the brass off the plastic before soaking in vinegar? If not, does the vinegar eat at the plastic?
A thicker glue or adhesive, 2 part epoxy, gorilla glue, Silicon RTV (Clear), contact cement, etc. Don't use superglue as it doesn't have the torsional strength. I use a dot of Silicone RTV. A SMALL DOT! or it will ooze out everywhere.
That is a superglue as well (in my experience) and I agree that it may not be the best of choices as a knock could cause the glue to 'fracture' and the cap to fly off. I have used contact cement as Larry suggests with good results on these. Sure you could use epoxy but likely you'll never get the darn thing off again should you need/want to. The contact cement held well and I have little doubt I could remove it again if necessary and clean off the residual glue easily.What are thoughts on using Loctite?
