c-atle-79bay
Super Member
Hi All, I picked up a set of TDL reference standards, and despite how good they sound I do have some issues that are going to need corrected to make them perfect.
1st - All domes have been pushed in, but new domes diaphragm and mounting plates (no magnet) that seem like likely matches are available on ebay, and the important detail he has enough for a full set of 4. They look the same, I have no proof they are the same, and know of 1 difference, mine say they are 16ohm on the magnet structure and he lists his as 4 ohm. I have not measured the impedance on the diaphragm it's self. I was also able to push all of mine back out, with only 1 crack. I've had it suggested that I can use resistors to adjust for this, anything else I can do, any downsides to that suggestion? The seller apparently bought the remaining stock of the IMF factory in Michigan.
2nd - One of the woofers has a bunch of nasty looking corrosion like battery acid stuff on the terminals and the leads are green, it moves freely but does not play any sound at all, again I have not tested it with the multi meter but plan do as time permits, any advice on cleaning the leads? I wiped the white stuff off and it did not seem to be any more than surface stuff but it did not change anything, Any other ideas to fix after more diagnose? And what would I actually be looking for in a diagnosis?
Any other advice thoughts or requests are welcome, I want to make these guys sing and go all in. Until my SO buries me in them that is.
Thanks
Thanks
