AMX390
New Member
Looking for some help with a minor rewind issue on an x10r that is otherwise excellent. When I rewind to the right, everything works great and rewinds very fast. When it stops, the tensioner arms ends up like this:
It will play or rewind again, no problems. When I rewind to the left reel, the tensioner arms end up like this:
It leaves slack in the tape and makes the micro switch on the tensioner arm, requiring me to manually tighten up the tape so that the micro-switch breaks, allowing it to play or rewind again. I have tried every combination of spring adjustment on the tensioner arms to no avail and causing other problems such as shutting down during a rewind from hitting the micro switch. What other adjustment can I make to eliminate the slack on a left side rewind? Thanks in advance.
