OK,... I'll just keep plugging away here; maybe it will hook, eventually?
We had an area that was exposed to winter frost kill in a sensitive succulent groundcover. It was thick in thatch, and, non-native grasses were coming up through it. So, I took the scuffle hoe and cut all the junk out.. This left the slope barren.
All the bare soil has just been scraped clean down below the root level.
As of friday:
As I mentioned, I'm a rock gardener. I plant rocks, because they don't die.
I planted many rocks this weekend (well, for a whole lot longer than just this weekend, but for another rambling,..). And I planted some really big ones!
THe slope that you see is sort of our "back way" up to the swimming pool mechanical area. It is just a dirt path, and skirted along the face of that barren slope. In wet times it was slippery. So, I decided to throw many many 200->400lb granite boulders at it over the weekend, rock garden style.
as of this evening, three days later:
There is an odd gap between the first steps and the second pair.It is an unfortunate result of a barely buried irrigation manifold pipe set. I graveled it in, and put a few small stepping stones over it to keep it accessible.
The area at the top is where it starts to level back into the grade; That area is going to be covered in 3/4" crushed rock as a waliing pathway surface. The area at the very base is going to be in 3/4" gravel as well. But, I've got to get more of it.
So, this was a three day pathway project, and is as of this evening.
Now, its been turned over to Sarge to make it all pretty with plants and stuff.
