I adjusted my 850 last night, and I did the same thing as mentioned above so I don't know how far off it might have been to begin with. Anyways, it is exact now.
I found the process on the 850 to be a little more work than when I did my 880. The 880 I could simply remove the top and access everything I needed to get the job done, with the 850 I had to also remove the bottom cover and stand the unit on its side to do the adjustments. Hardly a difficult task, but still a little more work than the 880 was (I know, I am very lazy).
Best purchase under $2.00 I have ever made has to be the little clip-things that go onto the ends of the multimeter test probes. I doubt that I would have been able to do the job without them at all on the 850, I was able to do the 880 without them but it was much more of a pain in the ass than it should have been. They clipped right on to the posts and allowed me to easily make my adjustments. It was a fairly simple matter, except for those ultra-sensitive little bitch-ass pots for making the actual adjustments. The bias ones weren't as bad as the offset pots, damn those things are aggravating. I would get it so close to zero and then just nudge it a little too much and holy crap it would fly up to like 20 and I would cuss and fume and try to carefully get it back to zero and then the same damn thing all over again... :gigglemad ... But in the end I got everything right up to spec
I also would like to say at this point that the guy who was posting that thread earlier about was Pioneer ever any good clearly never saw the inside of an sx-850! Especially for a mid-line receiver the thing is absolutely built like a battleship, I mean to the point of being ridiculous. I was also realizing how lucky I was to get this particular 850, I got it from my local Goodwill for $40 a while back and have been using it ever since. When I had it all open last night I realized that it is still looking like the day it came out of the factory inside, barely any dust, all boards are clean, just beautiful! I spent a good half-hour when I was finished just checking it all out and admiring it, the sx850 is truly a beautiful piece of audio gear inside and out.
Thanks again to all for the input and advice, I did end up soldering up a pair of plugs with the appropriate resistors for the job. As far as I was concerned it just made the job more fun! I wish I had a digital camera so I could have taken a few pics along the way, but next time...
