Hello,
I have an issue with a 1981 Technics SA-424 receiver, concerning the tuner section.
When I initially turn the receiver on and have it in the tuner mode, it will not have the quartz lock and the FM stereo lights or audio working. Just silence?
It works fine in mono upon powering it on, but no FM stereo or quartz lock working.
That is until about approximately 15 minutes have past, and then it is working perfectly in FM stereo, along with the quartz lock light on, and perfect audio in stereo.
I've cleaner this unit multiple times with Deoxit D5, faderlube, and just tried some CRC contact cleaner.
I've tried the tape outputs, along with the Aux, and it played a tape and CD perfectly.
The only issue I'm having is the unit not initially starting up in FM stereo when powered on?
Only after is has been running awhile, and warmed up, that it will lock onto FM stereo audio perfectly.
Thanks in advance for any suggestions on solving this issue.
