slateef
Hello friends,
I've started to work on a Technics SA-5270. It was not powering on. The fuse inside (3A, 125 v) was burnt out. I replaced it. When I powered it on, I immediately noted smoke coming from one of the resistors, R631. After the smoke, 2-3 seconds later, the same resistor started glowing bright orange/red. I turned the power off. I have removed R631 in hopes of replacing it, but what else should I do before trying to power it on again?
And advice would be much appreciated.
ETA: Can a mod please change the thread title for me; I mistakenly typed SAS instead of SA. Thank you.
