Hello,
I discovered this good forum while searching for problems encountered with the TECHNICS SA-700.
My neighbor gave me an old TECHNICS SA-700 that was stored in his garage for a lot of years.
Yesterday I wanted to test it and I connected a CD player to the aux imputs.
I switched the amplifier on and the sound was really good and powerful but a few seconds later the amplifier started to emit a bad smell. I switched everything off.
In order to know where the smell was coming I removed the cover of the amplifier before switched it on again.
A few seconds after I saw a smoke coming from the PCB on the right of the power transformer (while facing the amplifier).
I waited for the smoke to disappear and I noticed a leak under C625 and C628 (100uF / 63V electrolytic capacitors) and there were still very hot.
Beside these capacitors R708 was a bit burnt but showed 650 ohm as it should.
I checked the other components and saw that R912 was also burnt (I don't understand why because it's far from C625 and C628) but still showed 1.8 kohm.
I took the enclosure apart to check the solder joints under the PCB and found out that the solder joint of the collector of TR701 (NEC D381 transistor) was cold so that the leg was not connected to the PCB anymore.
Do you think C625 and C628 blew because of this cold solder joint of TR701 so I just need to replace them (or replace all electrolytic capacitors if I want to be on the safe side), or could it be a another faulty component?
Thanks for your help.
