I am looking for some advice on where to go next. The left channel does not work on the turntable. So far, this is what I have tried:
1. Eliminated the stereo as the variable - I reversed the RCA cable on the phono input and the left channel started working and the right did not - so I know it's the output of the turntable
2. I measured the cartridge using an ohm meter - both sides registered about the same resistance
3. I removed the case and looked at the solder points on the RCA cable. A visual inspection did not reveal any frayed wires.
4. A visual inspection of the ground wire looked good as well.
5. I measured the resistance of the RCA cable from the solder points to the tip of the RCA cable and everything looks good.
6. I measured the resistance of all 4 wires from the cartridge up through the tone arm to the RCA cable.
There does not appear to be any physical breakage of the wires in the RCA cable or the 4 wires from the cartridge / stylus.
I did replace the cartridge with an Audio-Technica AT95E/HSB Headshell/Cartridge Combo Kit off Amazon.
I'm a bit at a loss. If there there something electrical going on in the turntable that is preventing the left channel from outputting audio?
Should I just replace the RCA cable anyway?
Thanks for any help
Thanks for any help
