Mark Davis
I was taking apart a SL23 to veneer and broke the Tonearm wires in the bottom where they go into the arm base.
I don't have enough wire to attach to the terminal strip. The plan is to rewire the Tonearm and replace the original RCA cables.
I have a few questions and recommendations needed.
1. Has anyone rewire this arm and if so how did you do it?
2. What Tonearm wire should I use. I have seen this KAB wire and litz mentioned.
3. I need recommendations on terminals to attach to the cartridge.
4. What RCA cables do you think I should use?
The veneer job went Great, I just need to fix the TT to be able to enjoy it.
