Airjmax
I have a Technics SL-D20 table in excellent condition and working order, with the exception of one problem. I can play 2-3 album sides with no issues, and soon after, a noticeable "buzz" comes through. If I touch the platter, the buzz will respond. I have a ground wire connected properly, and it does it on every receiver I own. I don't have buzzing / grounding problems with any other tables, so I don't suspect the house wiring to be the culprit. If I don't use the table for a few days, the buzz "resets" and I can play a few sides again before the buzz starts up again. I took off the bottom of the table, and the spot where the ground wire comes in looks perfectly fine - the wire is making a clean connection, and the wire it touches is definitely grounded to metal with no corrosion. I know someone can help, so thanks in advance!
