I've had this SL-D202 for many years. Now it won't spin when I move the arm out. This problem started suddenly, just now. After powering off, it will start spinning for a second, then die out again. I sprayed some contact cleaner on the pitch control, but that didn't help.
It's somewhat chilly in my basement, around 56. Been that way for a while now since it's winter. And just before this started, I went to grab the finger lift and there was a small static discharge that I heard thru the speakers. Could that have fried something? As I said, it will occasionally start for a second, then stop.
Any ideas? HELP!
Edit: And now it's working again! Why would there be an intermittent problem like that? Is it the mechanism that starts the motor?
Edit 2: dead again. Stopped during playback
Edit 3: If I wait a while and get it going, leave the tonearm over the record, I can turn the power off, then back on, and it will resume spinning, no problem. I can do this repeatedly. But if I move the tonearm back to the rest, where it turns off the motor, then try to start it again, it won't spin. Does this point to the starting mechanism?
Any ideas? HELP!
