Eastham
More Class-A than ever!
Grabbed myself a Technics SL - P2 for the costly sum of £20 advertised as "Disc not spinning"
It got here today and sure enough it didn't play so, I cracked it open and found the laser sled wasn't in it's resting place, moved it back, put a disc in and it played, until about 1:40 when it would just jump back in the CD. So I dug deeper and found that the laser sled and the disc drawer drive belts are both completely dried out and rock solid...
So while it's all apart I decided to clean and lube everything, gave the motors a drop of oil, put a thin layer of lithium grease on the slidey parts and everything moves quietly and freely like it should.
I've got a pair of belts on the way Royal mail first class! No mucking about, one 50mm in circumference and one 25mm. Or 2 inch and a 1 inch for those using freedom units.
