Technics SU-V9 Amplifier question?
Discussion in 'Solid State' started by Ibemiked, Jan 14, 2019 at 7:30 AM.
  1. Ibemiked
    Ibemiked Active Member
    132
    Picked up a nice vintage Technics rack system few months back it included the following
    Technics SU-V9 Integrated Amp
    Technics SH-8055 Spec Analyzer Eq
    Technics ST-S6 Tuner
    Technics SL-QX300 Turntable
    Technics SH-4020 Audio Timer
    Technics M245X Tape Deck
    The SU-V9 sounds and works great! 120WPC @ 8ohms and 0.003%THD! Only issue is the little light for the New Class A emblem located on the bottom right does not light up and it's also missing the glass door on the bottom.. both are issues I can live with. I was wondering if anyone has any knowledge about this amp and if the light is an easy fix? I'm sure the insides could use a good cleaning, some of the buttons are a little
    Scratchy when pressed.
    Also the ST-S6 seems to be possibly out of alignment? I'm no expert on repairing equipment but I thought I've heard tuners can need aligned? It's actually a very good Tuner with a lot of features you don't see on most tuners. It picks up every station but the quartz lock and stereo lights turn on for the wrong station (if that makes sense) for example the station is 97.5 and it comes in meters showing full signal but neither the stereo or quartz lock lights come on, the lights will come on at like 97.3 which is nothing (fuzz).. So I'm wondering if it's maybe an easy fix and if not is worth paying to have fixed? I know tuners aren't usually that valuable but this was on the higher end for Technics when new. This entire system was actually all Higher end when new. The SH-8055 works perfectly! I always wanted one of these to, i remember going to stores as a kid and being fascinated by spectrum analyzers and always wanted one.. the SL-QX300 is solid, replaced the stylus works perfectly. The cassette deck is the only thing that doesn't work.. it's tough finding tape decks that work these days.. I'm hoping it's an easy fix.. Not sure what the issue is with it.. it's an M245x anyone think it's worth putting money into? Hopefully someone will read this rant and have a few answers for me.. if not oh well..
  2. SVI2004A
    SVI2004A Synchro Bias
    2,021
    Albany Western Australia
    Bulbs are XAMR85S15 - 14V axial 0.05A (x2)
    Ibemiked likes this.
  3. slimecity
    slimecity Super Member
    3,156
    New Zealand
    Great score on the V9 - well done.
    I replaced my blown one in a V6 with an orange LED. Theres no point having that fancy badge unless its backlit IMO.....
  4. Ibemiked
    132
    So is it an easy fix replacing the bulb? Is it something an "amateur" could do? Is there any soldering required?
  5. slimecity
    3,156
    New Zealand
    Its been a while since I did mine - I think the bulb just slotted into a fitting. A photo of your bulb fitting inside the unit would help
    SVI2004A and Ibemiked like this.
  6. Ibemiked
    132
    I'm currently using this amp.. When I feel like switching it out for another amp I'll open it up and take some pics.. there may be a picture of the inside on an old AK post. Let me see if I can find it and take a screenshot. Thanks for the help man! Appreciate it!
    slimecity likes this.
  7. Ibemiked
    132
    Here's a stock photo I found, tried to zoom in on the area where the bulb is located on the 2nd photo.
