I posted earlier about the lamp problem I was having with my 2252B. I
thought the lamps were blown after replacing them but they weren't. I
still have a problem and need help. My stereo works great except
the dial and meter lamps will not light. The dial needle lights up,
the am/fm/phono/aux/tape red lights all work however the names in bright white don't light up. The bright white station lights don't work either (the little white dots). I have two fuses on the board to the right as you are looking down from the front. With the dial lamps in the lamp holders, the 2amp/250volt back fuse blows when I turn the unit on. I take the 5- 8v/200ma and the 2- 8v/250ma meter lamps out and put a new
2amp/250volt fuse in, turn the unit on and the fuse does not blow.
I checked the lamp holders for ac voltage and all seven checked 8.18 volts. By the way I buy all my lamps from Vintage Electronics and have never had a problem with them with the other 5 Marantz stereos I've worked on.
Someone suggested there is an actual short from
one of the lamp sockets to some other circuit or the frame that is
causing the fuse to blow, so in fact the fuse is doing its job
perfectly, and you need to figure out where the short is. He also suggested: Try looking for a short first with your meter, with fuse lamps in but power OFF. I checked the continuity on each lamp holder with the lamps out and I got a beep on all of them. Is there suppose to be continuity there without a lamp being in the lamp holder? I also did the same thing to the 250v fuse holder, checked continuity with the fuse out and got a beep. How exactly does one check for shorts?? I'm pulling my hair out, what little I have left...James
