Testing output on MC2255
Discussion in 'McIntosh Audio' started by saltpeter, Jan 9, 2018.
  1. saltpeter
    saltpeter New Member
    31
    I just received a well used 2255 and would like to know how to test the output.
    Initial test with a signal generator and no speakers connected shows the meter on the right channel to be much lower.
    Is this an accurate enough test, or should I use a multi-meter and test the output connectors with the speakers connected?
  2. damacman
    8,991
    Gilbert, AZ
    You'll need the following:
    Sine generator
    Oscilloscope
    Distortion Detector
    Resistive load bank
    Or something like an Audio Precision.
  3. c_dk
    c_dk Addicted Member
    6,420
    West Michigan
    To properly test output and calibrate the meters you need a 8 ohm load box with sufficient heat soak capabilities, a signal generator and a appropriate meter that will read voltages accurately across the audio spectrum not just around 60 hz.
    Typically those last two needs are satisfied with a distortion analyzer.
  4. saltpeter
    31
    I'd like to check the amp output for even power on both channels, if the meters aren't calibrated that is ok for now.
    I only have a signal generator on the iphone with a cable that has RCA jacks.
    I was going to connect the phone signal to the 2255 inputs, then check the speaker terminals for voltage.
    That won't test the output at the terminals properly?
  5. clinic-audio
    2,275
    France
    You need to use load at the output terminal of your MC2255 ;
    Use the same value (8 ohm) and terminal plug (8 ohm) if you wish a precise result
    Don't forget that meter are used for indication purposes only
    using signal generator with iphone is not serious measurement
  6. saltpeter
    31
    Thanks, I am planning to connect the speakers for load, and then measure the 8 ohm terminals.
    I had an idea this would not be a precise result, but I am hoping it is ok for my purpose.
    I'm just wanting to see that the output is of reasonably similar strength in both channels.
  7. damacman
    8,991
    Gilbert, AZ
    Bad idea. Most speakers cannot handle pure sine waves at any power level to speak of. You could very easily cook the mids, tweeters, crossover components, or some combination thereof.
    Given the age of the amplifier, you’ll be time and money ahead having it brought back to spec by a qualified technician.
  8. clinic-audio
    2,275
    France
    We don't use speakers as load , the reason is simple . When we check a powerfull amp we don't disturb our neighbour !
    Use 8 ohm loads , it is much better for your speakers !
  9. saltpeter
    31
    ok thanks, this might not be happening then. :eek:
    Would a pink noise generator be safe for the speakers?
  10. MACKIE1975
    MACKIE1975 Well-Known Member
    799
    If it sounds good, enjoy the music else leave it to the pro
  11. jbailey930
    jbailey930 AK Member Subscriber
    864
    N. Va
    op may be looking to do something similar to this setup -
    Dummy 8ohm loads from Parts Express - B&K signal generator and a DMM.
    and help from an EE that knows how to do this and calculate power based on output voltage.
    ossidian, 62caddy and nj pheonix like this.
  12. saltpeter
    31
  13. damacman
    8,991
    Gilbert, AZ
    Sure, give it a whirl. But it won't work. Ohm's Law, as written, applies to DC Circuits whereas your MC2255 creates AC at its output. Furthermore, the impedance of a loudspeaker varies based on frequency, so any calculation you would perform would be like measuring wind with a tape measure.
    I know that we're not giving you the answer you're looking for but there really is no easy way to do this. Is there a reason that you're opposed to having this service performed by a qualified individual that does have the necessary test equipment? The old saying, "You rarely save money by saving money" surely applies here. You have in your possession a former top of the line McIntosh power amplifier which is incredibly complex. It'd be a shame to cause damage to it in this fashion.
  14. damacman
    8,991
    Gilbert, AZ
    Bingo.
  15. saltpeter
    31
    So I won't be testing the output terminals myself, thanks for the words of caution.
    If there were a local (SF Bay Area) technician I would go there. I am loathe to ship the unit right now.
  16. damacman
    8,991
    Gilbert, AZ
    Actually, this has been discussed here extensively. Let's solicit input from @4-2-7 and @gmc . You may also search the Mc forum here for SF Bay tech. Man, you got my mouth watering for some fresh seafood from Sausalito ...
  17. 4-2-7
    29,781
    San Francisco Peninsula
    Yeah I think there is a thread going somewhere, maybe the mac forum for local techs.
    House of Music recommended L&M to me a year ago to take my MC275 to and they worked under the mac warranty but are now closed for good due to retirement.
    House of Music SF
    A sleek shop offering top-of-the-line speakers & sound systems, plus repair & installation services.
    Address: 410 Harriet St, San Francisco, CA 94103
    Phone: (415) 255-0888
  18. saltpeter
    31
    SF and Berkeley used to be meccas of hi fidelity sales and service.
    Now, I wouldn't let most of the available "techs" near my boombox. :cool:
  19. gmc
    gmc AK Subscriber Subscriber
    608
    Southern California
  20. 4-2-7
    29,781
