    Dismiss Notice
Testing transistors
Discussion in 'DIY' started by avionic, Dec 30, 2008.
  1. avionic
    44,613
    Fort Dodge, Iowa
    Testing BJT transistors for shorts or opens.
    The majority of "Bad" transistors are due to shorted junctions. This is my attempt to simplify the routine for those that may not already know the process.
    Photo 1
    Transistor lead identification - If this is unknown you will need to find a spec sheet on the transistor under test.Sometimes it is provided on the schematics " legend" or even silkscreened on the printed circuit board.
    Photos 2 & 3
    Testing the Base-Collector Junction***With your DMM in the Diode Check function -Attach test leads as shown.One direction should show -OL(open) - and in the other direction a similiar value to the one depicted in the photo ,depending on whether its a PNP or NPN determines the direction of conduction.
    Photos 4 & 5
    Testing the Emitter-Collector Junction*** As seen in photo. Both directions should show (open) in a good transistor reguardless of NPN or PNP.
    Photos 6 & 7
    Testing the Emitter-Base Junction*** Again depending on NPN or PNP. One direction will show (open) and the other direction a similiar value to the example depicted in the photo.
    NOTE:The transistor in the photo is a " serviceable " example. ONsemi MJL4302A PNP
    If your meter at any time - beeps continuously - and/or reads a low value close to zero . First verify your test leads are not touching.If they are not touching ---You have identified a faulty junction and a unserviceable transistor.
    Good luck..I hope this is helpful..
    Dave
  2. Hyperion
    48,611
    Hertfordshire, UK
    I think this is the first time I have seen pictures of a transistor connected to a DMM with the correct DMM reading showing in the picture for the transistor under test.
    Thanks for taking the trouble to illustrate this Dave. :thumbsup:
    John
    avionic and Soundork like this.
  3. Ausjoe
    Ausjoe Super Member
    3,393
    South of the Colorado, Texas
    Nice work!
    avionic likes this.
  4. roggom
    roggom Super Member
    1,016
    Firestone, CO
    Great tutorial, this question comes up from time to time. Very clear and concise.
    avionic likes this.
  5. Chazb11
    Chazb11 Vintage Human
    2,214
    Ocean City, Maryland
    Many thanks avionic! I already had this info somewhere but this is much more easy to follow. I'm going to print the post and keep it on my bench.
    avionic likes this.
  6. thedruid
    thedruid Greetings Earthlings
    217
    Milton, FL
    You can take this a step further and test IC's in much the same manner. With the DMM in the diode setting place the + lead on the ground pin of the IC. Then place the - lead on each of the other pins and you should get a reading pretty much the same as the transistor junctions, anywhere from 500-700 is usually a good reading.
    avionic likes this.
  7. tensleep
    tensleep AK Subscriber Subscriber
    6,979
    Dallas Metroplex
    Thanks for the photo tutorial, Avionic; I will be using this in the near future.
    So, how about testing the transistor in situ? Desoldering/soldering can have adverse effects on the circuit board.
    avionic likes this.
  8. premiumplus
    premiumplus Vintage Junkie
    275
    Swartz Creek, MI
    Very good advice, but be aware that some types of transistors, particularly TO-3 cased ones, are actually darlington pairs on one die, and they will have different voltage drops, as will germanium transistors. And some actually have built in resistors that will read 100 ohms or so, but they are actually good devices. A spec sheet should always be consulted if you get bizarre readings.
    avionic likes this.
  9. avionic
    44,613
    Fort Dodge, Iowa
    Testing a transistor with a DMM needs to be done out of circuit..period!
  10. 2chanman
    2chanman Well-Known Member
    690
    Stamford, Connecticut.
    To tensleep:
    Regarding testing transistors in situ: There will be circuit paths through the components connected to the transistor that will affect ohmmeter readings. The only sure way to be sure is to remove the transistor from it's circuit location when attempting to determine it's condition.
    avionic likes this.
  11. tensleep
    6,979
    Dallas Metroplex
    Gotcha! Thx.
    avionic likes this.
  12. avionic
    44,613
    Fort Dodge, Iowa
    Roger that...Some transistors have built in diodes as well..
    I will also test a new transistor before installing in the circuit. It has happened that I have gotten defective "New" transistors..:yes:
  13. jaymanaa
    jaymanaa RIP 1961-2018
    54,284
    OZ
    Ahhh, so thats what them little devils look like.:D
    avionic likes this.
  14. EchoWars
    EchoWars Hiding in Honduras
    28,399
    Kansas City
    Might add that, simply because a transistor passes a diode-junction test, doesn't mean it is a good one. Simply means it isn't shorted or open (meaning that it apparently has no gross failures).
    avionic and merlynski like this.
  15. avionic
    44,613
    Fort Dodge, Iowa
    Very much agreed. So I edited thread topic..In reality one should do a little research and reading as to the theory of operation for transistors,If you don't know how its suppose to work-How in the hell can you find the problem.....
  16. jaymanaa
    54,284
    OZ
    What about those little sockets on some VOMs (labeled NPN and PNP)? and what about matching pairs up?:scratch2:
    avionic likes this.
  17. avionic
    44,613
    Fort Dodge, Iowa
    Thats another thread Jay...I'll get right on it...:D
    Goldie99 likes this.
  18. Hokieman
    Hokieman Super Member
    1,120
    Dayton, OH
    Thank you kind sir!
    avionic likes this.
  19. chadbang
    chadbang Well-Known Member
    815
    Far From Home
    I thought I would add this for determining the base, emitter and collector
    Most Digital Multi-Meters (DMM's) have a diode test function the symbol looks something like this >| (picture the greater than sign as a black triangle pointing to and touching the redline).
    Initially you should practice on a known good transistor, so you'll be able to tell if you have a bad one.
    1) Ensure the transistor is out of circuit.
    2) Set the DMM to the diode function.
    3) Touch the positive (red) and negative (black) probes to any two leads on the transistor until you get a reading other than infinity.
    4) Once you get a reading leave one of the probes on one of the leads (it doesn't matter which one).
    5) Take the other probe and touch the third lead. If you don't get a reading other than infinity go back to step 4, this time leave the other probe on the lead it was originally on, when you got the reading other than infinity.
    6) Now take the other probe and touch it to the third lead, you should get a reading other than infinity. If not, go back and repeat steps 3-6, but start with 2 different leads, until you can leave 1 lead in place and get a reading other than infinity on the other 2 leads.
    7) If you kept the Positive lead in place you have an NPN transistor. If you kept the Negative lead in place you have a PNP transistor.
    8) The probe you left in place denotes the Base.
    9) On the probe that you swapped, the lead with the lower reading is the Collector and the lead with the higher reading is the Emitter.
    Read more: http://wiki.answers.com/Q/How_do_yo...itter_terminals_of_a_transistor#ixzz1Kt5eZEr1
  20. avionic
    44,613
    Fort Dodge, Iowa
    If your going to be testing a lot of transistors. Which I do. I love my little DCA.
    Bill Ferris likes this.
