The Fisher TX-50 Stereo Amp How Do I Hook The Speakers Up?
Discussion in 'Fisher' started by Rocketmanone, May 12, 2018.
  1. Rocketmanone
    Rocketmanone New Member
    2
    Help! At a loss on how to hook speakers up to this old "The Fisher" TX-50 Stereo Amp. Seems there's one post per speaker? Positive and negative for each speaker? I'm at a loss, not a lot of info out there on the interwebs for this vintage amp. Pictured is the speaker connections. Any advice would be greatly appreciated! IMG_9783.jpg
  2. RUmad
    RUmad AK Subscriber Subscriber
    942
    New York
    Positive to ‘main’, negative to ‘com’mon
  3. larryderouin
    22,218
    Glen Burnie Md.
    Correct. Common is NEGATIVE. MAIN and REMOTE should be self explanatory. It's NOT gonna run with a missing fuse and fuse cap.
  4. Rocketmanone
    2
    Awesome! Thanks! There a 2A fuse soldered inside the chassis...power light goes on.
  5. Masonavenut
    Masonavenut AK Subscriber Subscriber
    177
    Winnetka, Ca.
    Guys since the po’s request has been met I’m going to ask a question.
    When using this style of screw connector on our Fishers, what do you like to use as a wire end to connect to the amp/receiver?
    I’ve been using the type on the left in this pic.
  6. larryderouin
    22,218
    Glen Burnie Md.
  7. pdm4606
    pdm4606 Super Member
    2,954
    Las Cruces, NM
    An old Knight very early stereo amp I had was more confusing. The front panel labeled the channels as right or left. The inputs were labeled 1 or 2. And the speaker connections were labeled as A and B.
    You couldn't connect anything until I relabeled the connections as L or R.
