Was at the flea market yesterday, one vendor had a big stack of 1970s all in one systems, the type with an 8 track player, tuner, and cheap amp all built into one unit. $10 each... well hiding in the back I saw a "The Fisher" nameplate, and the component had a "Made in USA" look about it.. Asked how much, and was quoted $10 like the others... well I picked it up. Turns out to be a Fisher TX-50. Was hoping for tubes, but one can only be so lucky!
It has some candle wax on top of it, and some that went through the vents, but aside from that and being dirty, it's complete and in good shape, I believe it should clean up very well. All knobs are present and no scratches or anything. The back panel has crusty looking cadmium plating, but at this point I think that's fairly typical.
The capacitors are dated 1969, and are a mix of USA made parts, and some German capacitors too. The filter capacitor is actually a board mounted FP can.
Looks like a (maybe quasi?) complementary symmetry amplifier, with a capacitor coupled output, and single ended power supply. Internal construction is modular, there's lots of wires with pin connectors, and the overall quality is high. Sheet metal is thicker than on later or cheaper components.
Anyone ever try one of these? I am thinking it's probably all silicon transistors, given its age and construction. Does the Fisher solid state stuff of this era sound good? I really like the compact size, and USA made construction.
