If you have been around the Sansui Forum for any length of time you know that the 9090DB and it's variants, the 8080DB, 990DB and 890DB are the topics in many threads. They are arguably the most popular and most widely produced of all Sansui Receivers. The earliest serial number we have on file is from September 1976 and the last one on file is from May 1978. During that time they were in almost continuous production. 10s of thousands of them were built.
Over that time span, Sansui made many production changes to these units. Some are minor or obvious like the position of the filter cap in the tuner power supply or the color of the plating on the chassis. Others are more involved or hard to see.
The serial number database is set up to track production changes. That would give us a better view of what we are getting. To do this we need to crowd source data, specifically the configuration of your unit. This information can be added to serial numbers that are already on file in the database or to newly added serial numbers but in every case there needs to be a valid serial number tied to this data.
Please keep in mind that not all modifications are factory modifications. Over the years many of these units have been modified by their owners. Ideally, we need the information from virgin units and we all know how rare an actual 40 year old virgin is.
Off the top of my head here are the production changes that come to mind. Please feel free to chime in with any that I missed.
Chassis plating, gold or silver?
F-2624 Driver Board bias control, cylindrical transistor or forked black diode?
F-2657 Protection Board, speaker protection fuses or no fuses?
F-2619 Tuner Power Supply Board, Filter Cap - Pointed straight up, laid over on it's side or underneath?
F-2656 Power Supply Board - R30/R31 - 1 ohm fuse resistors or actual glass fuses?
And last but not least, the Dolby Circuit:
Green flex PC board between F-2655 Dolby Board and F-2654 Push Switch Board or Black ribbon wire?
F-2655 Dolby Board - Rivets in pass throughs? These rivets are extremely hard to see and takes a trained eye to report accurately.
I'll try to put together pictures to illustrate each of these production changes.
I'm going to set up a companion thread in the Sansui Database Forum to post this information. That will keep it more viable so it doesn't get lost over time.
Here's a link to the tracking thread. Let the tracking begin!
- Pete
- Pete
