The restoration of a Yamaha CA-2000 (Japanese CA-2010)
Discussion in 'Yamaha' started by Mr. Yamaha, Oct 4, 2017.
  1. Mr. Yamaha
    Mr. Yamaha Not so much Yamaha lately... Subscriber
    914
    Amsterdam Area, The Netherlands
    @Oilmaster decided to sell me one of his CA-2000's :angel:
    It needs a full restoration, so this will be my second big project. Nice project for winter times. It's completely original and untouched.
    Some pictures:
  2. Mr. Yamaha
    914
    Although I first need to finish my T-2 mini project and my also new Micro Seiki DDX-1000 project, I couldn't help myself. So I started with cleaning the front plate and all knobs.
    There appeared to be green corrosion on some knobs, but that turned out to be dirt :bigok:
    The faceplate is a different story, there is something on it. Not sure what it is, but it couldn't be removed with: normal cleaner, sticker remover, turpentine, white spirit and thinner. So, I'm a bit out of options there. Maybe some of you know a different approach. In the last pictures you can see it, there are some cloudy stains on the faceplate.
    Next steps: inventory of needed parts and to order them.
    KrautNotRice, RedSquare and avionic like this.
  3. Bert 1100
    Bert 1100 Super Member
    1,176
    Planquiri, Switzerland
    Beautiful amp !
    Does it run on 100V ?
    Maybe the white stains are some kind of corrosion ?
  4. amr2
    amr2 Well-Known Member
    595
    Nice project! :beerchug:
    I have observed that kind of stains on anodized pieces. I'll try to investigate...
    Mr. Yamaha likes this.
  5. mbz
    mbz Super Member
    2,546
    Melbourne, Victoria
    I'm currently doing a CA-2000 refurb. Some proprietry parts on the function board, hope there ok.
    Some hints,
    - take out a gym membership, serious weight.
    - remove L&R power amps to lighten the load, need to unsolder 4 "input" (+/-V, IN, GND) wires
    - Unsolder 4 wires connecting meters to meter board so front plate can be removed
    - Nichicon PW and EP caps on the power supply
    - measure all FR's replace if out of spec
    - replace VD1212's with 2 x 1N4148
    - I would not overdo the step down, buy a quality low noise isolation transformer (torroidal), 700VA
    would probably be ok, 1KVA plenty
  6. fernarias
    fernarias Super Member
    1,132
    Merced, CA
    It's damage to the sealant or clear coat on the anodized surface. Usually from using ammonia cleaners (windex for the US) or other harsh chemicals cleaners (water is the best cleaner). I have had luck with acrylic polish (like Future) to lessen the effects. Perhaps resealing with anodized sealant would work but I haven't tried (not until I get a garage, available here: http://www.caswellplating.com/anodizing-sealant-1-lb.html).
    Plastic parts can be repainted with lacquer paint like Alclad.
  7. rottalpha
    rottalpha Yamaholic Subscriber
    1,908
    Middle of Crook County
    I have a feeling MR Yamaha will take this restauration a bit further than that.
    Also, he should be in really good physical shape after that last B-2 restauration:thumbsup:
    Mr. Yamaha and saltwater like this.
  8. Mr. Yamaha
    914
    Yes, 100V! I need a proper transformer.
    Thx, some of those are allready on the list. VD1212's and FR's. I think this one is getting the Nichicon Muse treatment.
    Yes I was a bit afraid of that. You think it can be fixed without damaging the lettering?
  9. fernarias
    1,132
    Merced, CA
    I have had a lot of success with Future floor polish on Pioneer and Marantz faceplates(my Yamaha gear has been clean).
    This is what the product is called in the UK(perhaps Eurozone) https://www.amazon.co.uk/27OZ-FUTURE-FLOOR-FINISH-Kitchen/dp/B000ARPH4C . Future in the Netherlands is availalble here: "in superstore's like Edah and C-1000. Also look in "Super de Boer" and 'Albert Heijn' which is locally referred to as 'AH'"(got this info from a plastic modelers forum which is where this is mostly used, outside of cleaning floors).
    You're best bet is to ask about it in a Netherlands modeling community website and they will have the right name. Again it's just clear acrylic floor polish.
  10. Mr. Yamaha
    914
    Great info, thanks. Do you polish the surface including the letters or do you go around them?
  11. fernarias
    1,132
    Merced, CA
    This won't hurt the lettering. It's wipe on and let dry. Try it on a small patch first.
  12. pfcs49
    pfcs49 Phil Subscriber
    2,400
    N/W NJ, USA
    The largest button on my PX-2 turntable is ugly! Some one scratch it and I tried sanding it out only to discover that it isn't brushed aluminum, it's some kind of finish over plastic!
    Anybody know how I can refinish it to look original?
  13. avionic
    47,490
    Fort Dodge, Iowa
  14. pfcs49
    2,400
    N/W NJ, USA
    @avionic:
    Find a parts unit.
    Isn't that the "down" button ?
    Good used button would be best, but I haven't seen one in 3 years!
    Yes, it is the 3-wide down button below L/R/Up buttons
    The linked product wouldn't seem to work well; the button is 3D with sides
  15. avionic
    47,490
    Fort Dodge, Iowa
    Look better that what you have now..
  16. pfcs49
    2,400
    N/W NJ, USA
    True, but the deck is nearly perfect excepting that button! I'll continue to look for used.
  17. Mr. Yamaha
    914
    Some stripping has been done here.. :cool:
    Ds2000 and Oldsansui441 like this.
  18. Oilmaster
    Oilmaster Drillers go deeper Subscriber
    1,290
    Paris & The Hague
    There lays my adopted puppy on the bench in pieces....:bye:
    The Fez and Mr. Yamaha like this.
  19. Mr. Yamaha
    914
    A question on the Tantalum discussion. In the phono section there's eight 100 uF tantalum capacitors in the signal path (C101 - C108). I was planning on replacing them with new AVX tantalums, but they are pretty expensive. Is there any drawback by replacing them with eight 100 uF Nichicon FG's?
    Were they chosen in the 70's because of there physical size against electrolytics or were the chosen for their sonic performance? :idea:
    Even stranger, according to the schematics (of a CA-2010) they should be 33 uF and 220 uF, but the ones in this CA-2000 are all 100 uF, four rated 6.3V and four rated 10V.
    Oldsansui441 and Ds2000 like this.
  20. ivandezande
    ivandezande Super Member
    2,069
    Twin Cities
    Size, every time. Replace those with the ones you want to (the FG). Tant caps actually have pretty high distortion I believe actually when being used to pass AC, no sonic benefit there.
