Hey, I'm new and I'm ignorant.
I've been trying to edumacate myself on the "simplicity" of tube amp design ever since acquiring several cheapo amps (norh se9, consonance M99 Plus and jolida 202A).
Why so many amps? well, I got them pretty cheap and I wanted to compare Class A SE vs. class AB, EL34 vs KT66. Long story short they all sound different, but they each sound infinitely BETTER than my previous SS gear (NAD, Philips, Proton and Harman Kardon).
So here goes (deep breath)... I got AC from the wall into the amp, then after going through several stages out comes a signal from the output transformers that drives the speakers.
So what is happening in between?
I know it is different for each amp... the norh is class A and not push/pull, the consonance and the jolida are more similar, using class AB, some global feedback but the consonance has an SRPP drive stage whatever that means.
But where does the AC go first, the power transformer or the rectifier? is AC converted to DC when the current travels from the cathode to the anode in the power valves, or does it occur earlier? And is the drive tube role only to increase the voltage signal from the music source and send it to the power tubes for further gain increase?
Why does the norh only have one drive stage while the jolida and consonance appear to have 2? why does the norh use a tube rectifier, while the consonance and jolida don't?
I have sooo many basic questions... HELP!
