Thermal compound becomes liquid when hot : normal ?
Discussion in 'Solid State' started by Bert 1100, Mar 2, 2017.
  1. Bert 1100
    Bert 1100 Super Member
    1,176
    Planquiri, Switzerland
    I noticed yesterday that the thermal compound I use becomes very runny once it is heated up.
    When cold it is very thick, but once at maybe 80 degrees centigrade it is runny and the extra paste starts flowing and running off.
    I noticed this yesterday when I did a differential pair of transistors with the paste in between them and I was heating the shrink sleeve I had put around them.
    Then this morning I did a voltage regulator that gets quite hot, soon after switch on the fresh paste becomes liquid...
    So.. is it normal or did I buy junk ? It is a tube, supposedly made in Germany, bought from ebay...:confused:
    Thank you !
  2. Hyperion
    50,211
    Hertfordshire, UK
    Never had that problem, the current tube I am using is 'Dow Corning 340' - I forget where I got it from, but it definitely wasn't ebay.
  3. Bert 1100
    1,176
    Thanks, I think I'll get some Dow Corning 340 from a reputable source.
    Thermal compound is not something to play with :eek:
  4. elnaldo
    elnaldo Addicted Member
    7,561
    Buenos Aires GMT-3
    I think the viscosity at different temperatures is detailed in the datasheets. That will give you an idea if it's normal or not.
    Remember to apply a very thin coat of it.
  5. whoaru99
    whoaru99 Epic Member
    40,895
    LoTL
    I might be more concerned with the 80C first? :idea:
    mech986 likes this.
  6. ConradH
    ConradH Addicted Member
    8,110
    Canandaigua, NY
    You might have gotten lucky. Read about phase change thermal compounds. Aavid is the one I know, but no doubt there are others. They liquefy when they get hot, resulting in a smaller gap and better performance. They're expensive. https://www.aavid.com/product-group/interface/phase-change
    Or, you might have something weird!
  7. Blue Shadow
    22,559
    SE PA
    47 grams of that good stuff cost about what a pound of the regular grease is.
  8. Bert 1100
    1,176
    Well, I noticed that quality when I was doing the heatshrink on two diff pair transistors, so the temperature was applied. Of course this diff pair does not get hot.
    Now, that voltage regulator to-220 does get quite hot, maybe 60 deg. C.
    In fact my paste gets liquidy at maybe 50 deg. C, and that can't be good...or can it ?
    I definitely don't have the aavid stuff.
  9. ConradH
    8,110
    Canandaigua, NY
    Is there any description of what you've got? Part number or something? Most silicone based thermal greases don't change viscosity much when heated. The Aavid product is a lot like very soft white candle wax in the way it liquefies.
  10. Bert 1100
    1,176
    Thats what it looks like.
    I just saw on a german forum somebody mentioning that the "non toxic" stuff is often based on wax, thats what it feels like actually....
    A little heat, it becomes liquid, let it cool down and it will be thick again.
    So what do the experts say ? use it ? or get some dow corning 340 (or other ? suggestions welcome!)
    I'm about to place an order with mouser, so if anybody has a reference from them....
    Thank you !
  11. roger2
    roger2 . Subscriber
    3,307
    Don't use it, that should be obvious I think :)
    If you are ordering from mouser get what Hyperion suggested if they have it. Or get this: http://www.digikey.com/product-detail/en/120-2/345-1007-ND/340305
    which is what EW has recommended in the past. The Wakefield also comes in small 4gram size which is more than enough for many applications IF spread very thin as should be done.
    EDIT: link corrected
  12. hnash53
    hnash53 AK Subscriber Subscriber
    2,762
    The beautiful Oregon Coast
    Maybe it froze and its molecular behavior has changed???
  13. whoaru99
    40,895
    LoTL
    I have a small jar of Wakefield Type 120 that I use. I've observed no unusual behavior of it.
  14. ConradH
    8,110
    Canandaigua, NY
    That's exactly how the Aavid stuff works. The trick is you use very little of it, so capillary action keeps it in place, or wipe around the device with a rag while it's warm. I like it because I understand how it works and know it's better, if different than what you're used to. Others hate it, so do what you like. Remember that devices and heat sinks should be close to the same temperature. If you put your finger on a device and it's a lot hotter than the heat sink close by, the thermal connection isn't what it should be. The thermal compound needs to be present, but it needs to be as thin as possible- most people slather it on too heavily. The phase change (it melts) stuff solves that problem.
  15. Bert 1100
    1,176
    Interesting answers !
    Thanks all !
  16. Jim Marantz
    Jim Marantz Active Member
    152
    I use Super Lube's heat-sink compound which works the same way. Very thin after it heats up. It seems to work very well just like the rest of their products. I've never had a problem.
  17. markn2wae
    markn2wae Mark T N2WAE
    3,020
    Scotch Plains, New Jersey
    Passing note- NEVER use Arctic Silver (the one that is silver based) on ENERGIZED devices (those that have Voltage applied to the device housing or tab)
    Mark T. :music:
  18. Bert 1100
    1,176
    Yes, that's very clear, thanks for the warning anyway!
    I've got some wakefield-vette 120-2 from mouser on the way, we'll see how that behaves...
    In the meanwhile I'm not worried anymore that I've been using some sub-standard stuff, thank you AK :)
