Thermistor: 1K TD5-C210/Adcom GFA-555
Mayank
Well-Known Member
Hi:
I need to replace a broken thermistor on the Adcom GFA-555. The service manual specifies this to be TDS-C210 1K thermistor. Unfortunately, I have not been able to find its specifications, datasheet or references to substitutes.
Would it be OK to replace it with this one from EPCOS/TDK:
B57164K0102K000 EPCOS / TDK | Mouser
Thanks in advance,
Mayank
assuming no overheating issues? if size is right and will fit at value 1k.. sure. i.e. if nothing comparatively different, it's simply a resistor as that it heats up and r value increases.
