Thinking of adding a sub with my DQ-10s
Discussion in 'Speakers' started by CavScout, Mar 20, 2017.
  1. CavScout
    CavScout Active Member
    339
    I am thinking of adding a sub with my Dahlquist speakers but I don't even know how or what product to buy.
    can anyone recommend something perhaps?
    perhaps something that is listed on eBay and something that is vintage ?
    I guess I will have to run this sub from a different amp ?
  2. nexus
    nexus Super Member
    1,578
    the signpost up ahead
    tmk, Dahlquist made a sub to go with their DQ series speakers. probably nowadays you could find a decent PE sub that would perform better..
  3. whoaru99
    whoaru99 Epic Member
    39,778
    LoTL
    Depends what you buy.
    Many subs these days have built-in amplifiers and some controls to facilitate dialing it in.
  4. CavScout
    339
    Yes, the DQ-1 , I just would prefer not to wait for one to show up for sale on EBay
  5. Blue Shadow
    Blue Shadow I gotta get me a new title
    18,451
    SE PA
    Dahlquist had available the DQ-LP1 Continuously Variable Low Pass Filter (electronic crossover) the MX-1 passive crossover and the DQ-1W to use with either of these.
    The woofer uses a 13" Seas driver and you can use it with either the MX-1 or use one, two or 4 with the LP-1.
    The LP-1 has a passive crossover to the main speakers, a highly desirable feature today as these still get some good coin. With stereo subs and/or mono blended subs, you can power 4 amps for 4 subs with it. The MX-1 has the one mono sub output and uses you main amp for power. Where are you located?
  6. CavScout
    339
    ...and my brain just melted as the ramistan jigglebobbed the friction evaporator's dynafow setting
  7. CavScout
    339
    I am in Calgary Alberta Canada
  8. dcmfan
    dcmfan AK Subscriber Subscriber
    3,666
    Dallas, TX
    I used a Velodyne sub from Craigslist with my DQ-10s. I think it was $50.
    The sub had a 300 watt amp and crossover built in and was super easy to integrate with the Dahlquists. I set the crossover at 50 Hz and used very little volume on it. It fleshed out the low end extremely well
    Bill Ferris likes this.
  9. CavScout
    339
    This is the only Dahlquist sub near me.
    It is a bit modern for my taste
