If youn recall.. I have been keeping you all informed of the progress I am making with my "new old" car--the 1988 Buick Riviera I bought a couple of weeks ago. It had a persistent, but intermittent miss in one cylinder. Plugs and wires did NOT help, and so I gave up, and had it diagnosed Wednesday. The #1 injector was NOT firing all of the time, and the shop thought the PCM was at fault. However..they did NOT have time to replace it. So, I took it home, and it did the "miss/no-miss thing.. I didn't go anywhere much Thursday, and Yesterday...I drove the car, it had it's usual problem.
Today, however, in between digging the blower resistor out of my mom's Malibu, I was going to get a new one, and was wanting to take my car. However--I wanted to try and remove the PCM and try and fix it.
However..(and I STILL don't really know why I did this.) I decided to do the "easy thing first", and check out if there was any connectors from the injector harnes that just MAY be the problem. I found the connector near the back of the PS Pump and alternator. It has 6 or 7wires and plugged into another plug, that led to a big wiring harness.
I pulled the "lock" out of the connector and it broke. SO..I removed it from the plug, and pushed the plug back and forth a few times, and them made sure it was tight. I then went back to see how hard getting to the engine computer is(and it is VERY hard to get at..harder than the blower resistor in my mothers car. )
However..the car was running and it felt like it was NOT missing..I put it in gear, and it did NOT mioss. SO..I drove it to Auto Zone to get the new resistor. It ran fine all the way there...and back. stops..No miss!!
Later tonight..I restarted it...no missing...I went to Krogers to get some gas...STILL no miss.. I decided to go on a "little drive" since it was runing VERY well, and smoothly. I reset the mileage calculator and drove about 25 miles altogether..about 60% highway, the other "in town..not ONE miss all of that time. It has GOOD power, and runs nicely in overdrive in 4th gear lockup.I was getting over 26 MPG average on the highway, and about 23 overall. When I parked the car..it was still running fine. I even gave it an "italian tune-up" just before going home. It accellerated from about 25 to 70 or so QUICKLY, and smoothly, with NO miss or stumbles!!
So...I wonder ..is THIS the problem I have had all along?? What is the chance that the connector is(was) causing the miss..and I have fixed it(for now..anyway...). Or..was this just "dumb luck" that it ran fine EVERY time I restarted it after messing with the connector??This is the LONGEST it has gone without missing since it started to miss. 5 stops altogether and restarts..no miss ANY of those times!!
What are the odds,....that the problem was that connector....and NOT the PCM?? And should I get some "de-ox-it" and clean up that connector, to insure it will not "mess up" again??
