Terracide
Member
I own a TD 104 that stopped working. I pulled it apart to see if i could detect anything. When i use a multimeter i detect no power on the motor it self when it's turned on. The lights on the speed selector still work. I used another power adapter to be sure (even when i measured it) and still same. The 104 is pure manual so there is not switch that can turnoff the motor.
I used a service manual: http://www.kevinchant.com/uploads/7/1/0/8/7108231/thorens_td104_105_service.pdf But i do not have much experience in this. I tried to measure the points that are known as testpoints, they all have voltage but they are all a bit lower as suggested. I measured the C112 capacitor that is the 25v, and that one still holds 24.7 so that one is probably ok. C113 looks a little dark on one side, i cannot measure it when it's soldered in but can C113 be my problem? I have a testtool that can measure capacitors but then i need to solder it out.
When i look at he diagram the T109 and T110 (part of the motorboard) should deliver 18V but they have 14.5 and 13.5V (with no load). So my guess (and i am a noob) it looks like the board has bad capacitors on the power circuit that deliver voltages too low....?
Anyone with more technical skills have any suggestions?
