Thorens TD160 & Pro-Ject Phono Box S setup
Discussion in 'Turntables' started by Yetiboy, Mar 20, 2017.
  1. Yetiboy
    Yetiboy New Member
    30
    I'm baaaaaaaack!
    Easy one this time. Got my preamp in the mail today, just want to make sure I have it set up properly for my cartridge.
    I'm pretty sure I have a Stanton 681EEE mkII S based on researching what came stock with the TD160 mkII, but I'm not 100% sure (pic included for possible confirmation).
    Based on what I read here:
    https://www.vinylengine.com/cartrid...chi=&stid=&masslo=&masshi=&notes=&prlo=&prhi=
    I should be using the following settings:
    Input gain = 40dB (seems to be the lowest setting according to the examples in the manual - picture also included) so 1 on, 2 off, 3 on
    Input impedance 47kohms (low-output MC cartridge, right?) so 4, 5, and 6 off
    Capacitance load 200pF (only options are 100, 200, then up to 320) so 7 on, 8 off
    Am I reading the info on both the above site and the instruction manual correctly?
  2. mprince
    mprince AK Subscriber Subscriber
    1,539
    Mooresville, NC
    Sounds right. Once you get it going you can experiment with different loading and see if it sounds better. Won't hurt a thing.
    Yetiboy likes this.
  3. Yetiboy
    Yetiboy New Member
    30
    Okay, good. My concern was potentially doing damage, glad to hear it shouldn't be an issue. And that I'm capable of reading both an instruction manual and data correctly. Thanks!
  4. Bugler
    Bugler Super Member
    1,755
    Pittsburgh, PA
    Stanton 681 series cartridges are not moving coil, but moving iron giving output voltages of about 2.8-5 mV which is basically in line with moving magnet.
    Yetiboy likes this.
  5. Bugler
    Bugler Super Member
    1,755
    Pittsburgh, PA
    Details available at vinylengine.com. You have to register but it's free. Great resource!
    Yetiboy likes this.
  6. Yetiboy
    Yetiboy New Member
    30
    Okay, good to know - I'll check it out, thanks!
    Bugler likes this.
