Hello - hoping I can get some help from the knowledgeable members here (longtime lurker, first time poster) regarding my Thorens TD280 (mk I).
I haven't been spinning much vinyl due to the belt slipping - and I hadn't gotten around to getting a replacement. So I sourced a new belt - cleaned the pulley and sub platter well - and installed the new belt. The belt is no longer slipping - however when I start it up it will not spin up to full speed on 33 or 45. both with the platter in place, as well as without the platter - the motor assembly is clicking and stuttering. Basically it's slipping, but the 280 does not have a slip clutch mechanism so the motor itself is slipping. If I give the platter a little assist it will spin up, stop clicking and seemingly run fine.
I've lubricated the sub platter and it spins freely. I've blown compressed air around all components and lubricated what I can access of the motor assembly but it appears to be a closed unit.
The last time I had used it I did not have this issue so I'm not sure what has gone awry other than a period of disuse (several years).
Replacement motors such as I've been able to find (an italian site listed here actually) are very very expensive - $170 ish USD which is not worth spending when I can add a bit more and get something else (used Rega for example).
So - any suggestions on things to try that I haven't? I've read the Thorens overhaul guide but it is mostly difficult to follow and I think targeted at models other than the TD 280 since I cannot find many of the items referenced.
Is the pulley removable from the motor spindle? If so maybe some deoxit down the spindle?
I fear the motor is shot - that one or more of the brushs is bad for example such that under load it can't overcome the short - but once spinning fully it can turn past the bad spot.
All input is appreciated - if it is shot any suggestions for a replacement in the $200-$300 range? I am using a Shure V15 VMR which I like quite a bit..
