Thought I would Share Here. GE Console RC-1350
Discussion in 'Tube Audio' started by Hitachiht550, Nov 6, 2017.
  1. Hitachiht550
    Hitachiht550 AK Subscriber Subscriber
    533
    College Station, TX
    15100174263551921063986.jpg As stated in the TT forum
    So I picked this up for a Christmas present for a friend that expressed interest in a working small console unit.
    Am I correct in thinking that the TT is a VoM? It has a vacuum built into the tonearm....Genius! Also has a dust-off slot to slide records in. I know that this thing will only see cheap records and some 78s but I find this thing fascinating.
    Left channel is weak and turntable needs some work and adjustment. Also needs some Deoxit. Anyone have any advice on this thing?
    Thanks
    Jason
    doctor fuse likes this.
  2. cademan
    cademan Addicted Member
    9,087
    Can't see any pics on my end. Try uploading directly from your computer to AudioKarma.
  3. Hitachiht550
    533
    College Station, TX
    How's that?
  4. cademan
    9,087
    That works. Thanks!
    Is that the unit that has the stereo push/pull 7355 amplifier?
  5. Hitachiht550
    533
    College Station, TX
    not sure on amp chassis. Haven't had time to really get into it.
  6. Tom Bavis
    Tom Bavis Audiophool Subscriber
    9,085
    Macedon NY
    Sams folder 586-7 covers it - I should have it.
  7. Hitachiht550
    533
    College Station, TX
    Awesome!
  8. gadget73
    37,812
    Southern NJ
    ah, the GE Megamaid console. Dustamatic? I think they called it.
    Looks like a VM. GE did actually make their own changers at one point but this doesn't have the look.
  9. danrclem
    danrclem AK Subscriber Subscriber
    1,779
    I'm pretty sure that you're right and it'll probably have PP 7355 output tubes.
  10. Hitachiht550
    533
    College Station, TX
    The FM tuner string rolled off the stem
  11. Hitachiht550
    533
    College Station, TX
    Reviving this to see if anyone has had any problems with output transformers going bad. So the left channel is totally out. I have switched all the left and right tubes on this to make sure it is not a bad tube. I also switched the outputs to the speakers and the speakers work. Seems the more I narrow things down I could have a bad output transformer. Anyone have any other ideas?
    Thanks
  12. orthophonic
    orthophonic Super Member
    1,332
    Winter Park, florida
    I would check capacitors/resistors first.
    That is the model that the Cleavers had on Leave it to Beaver.
    RUmad and Leland47 like this.
  13. FlaCharlie
    FlaCharlie AK Subscriber Subscriber
    785
    Gainesville, FL
    In your first post you said the left channel was weak, not dead. If it's now dead I would suspect that the output transformer is OK and that some other parts are the issue. As a first step, use the resistance chart found in the Sams to see if any are out of spec.
  14. Hitachiht550
    533
    College Station, TX
    Thanks. I will check it out. Think I will start ording the caps to begin working my way through it.
    So does anyone have a good tubing replacement? The original seems to have stiffened up and wants to pull the tone arm away from the spindle.
    Have a pic of the one in the Cleaver's house?
  15. tom3
    tom3 Super Member
    1,979
    So. Ohio
    That console have a reverb in it? Like to see some more pictures of the insides. Interesting console. GE made some real quality stuff that's not too well known.
  16. Hitachiht550
    533
    College Station, TX
    yep has a reverb and I will get some pics up later today
  17. Hitachiht550
    533
    College Station, TX
    Reverb Amp 20181012_154351.jpg Amp 20181012_154404.jpg Layout 20181012_154607.jpg
  18. KentTeffeteller
    26,341
    Athens, TN
    General Electric Company bought Glaser-Steers and began using a simplified version of this mechanism, with fewer features, beginning in 1965, to the sell off of their consumer phono lines around 1975 to Interstate Industries, who continued selling some of the line under the Concert Hall brand using BSR record changers.
  19. gadget73
    37,812
    Southern NJ
    So is this one a GE changer? Kinda looks like something based on the VM 1200 series. The GE changers from the mid 60s I'm used to are the ones in the Wildcat with that square-ended overarm.
