I've had an acrylic mat on my Delphi for over 20 years, before Oracle offered it as an option. I forget the brand name, but it has a slight concave dish machined into the top of it so the record edge contacts the mat even if it is slightly warped. It also has a peel and stick adhesive to couple the mat to the platter.
This adhesive is very important, and is not included with the XTM1 mat. Consequently the sound may be thin and/or bright as has already been noted. You could try double sided tape, or a fabric adhesive sprayed onto the mat.
Also absent is the concavity shaped into the top, but this is easily remedied with a Michell clamp and felt washer.
I personally like the sound of an acrylic mat and believe it is now a standard feature on the Delphi table. Bass is tight, harmonically clear and dynamic, as is the rest of the spectrum. The noise floor is also lower and there is less 'needle talk'
If you find you're not satisfied with it, do try the adhesive before giving up on it as it makes all the difference in the world.
