Thoughts on Balanced Cables
Discussion in 'McIntosh Audio' started by rocknroll1, Jun 6, 2018.
  1. rocknroll1
    rocknroll1 AK Subscriber Subscriber
    747
    Huntsville, Al
    I purchased a demo c1100 a few months ago and just added a pair of used 601's from AC's. I am new to higher end equipment and wanted your thoughts on balanced cables. Mike at AC said he a new pair for around $175 that in his opinion was as good as the higher priced ones without big name. I don't want to cheap out on cables after what I spent on equipment but don't want pay more than needed to just get a name. Sorry can't remember the brand. All my other equipment is vintage w/o balanced jacks so not much experience with that. I am not questioning the AC guys because have been very good to work and trust them. What are y'all thoughts on this.
  2. MACKIE1975
    MACKIE1975 Well-Known Member
    859
    Cable is sometimes likes snake oil. Go to Amazon and buy a pair of Amazonbasics balance cable. The quality is more than good enough.
    CruzBay likes this.
  3. Poinzy
    Poinzy Super Member
    2,009
    SE Michigan
    I buy my audio cables from places like Sweetwater and B&H. I get what technicians use in pro audio studio studios without paying designer prices. But it's your money.
    CruzBay, techguy0192 and mdewire like this.
  4. jtee1340
    jtee1340 AK Subscriber Subscriber
    533
    Tampa Florida
    Second on Sweetwater:thumbsup:
  5. isotopesope
    isotopesope Active Member
    183
    colorado springs
    i go to http://www.bluejeanscable.com/ for all my interconnects. high quality, affordable, and snake oil free. i have their LC-1 RCA's for my two channel setup and their balanced XLR's in my Marantz HT setup.
  6. Yamaki
    4,386
    Hillsboro, Oregon
    I initially used some generic unbalanced RCA cables from my DAC to the MX135 and from the MX135 to the MC501's. I switched over to balanced XLR's using Audioquest Cinnamon cables at the suggestion of a friend. My first impression was it sounded the same but the more I listened, the more I heard.
    A few years later I decided to upgrade and standardize all my power and interconnect to Wireworld cables, once again at the suggestion of that same friend. I was beginning to think he's an audio upgrade enabler having convinced me to upgrade the pre-amp, DAC & R/L main amps to McIntosh gear prior to the cabling upgrade. However, I digress.
    Once I had upgraded the cabling and sat back to really listen I noticed I was hearing even more detail.
    Call it snake or or not but I like upgraded cables and I like the balanced XLR connection over the unbalanced RCA connection.
    Good luck with your cable upgrades.
  7. exhippy
    exhippy I use to have long hair. Now I'm lucky to have any Subscriber
    1,384
    St. Louis County, MO. U.S.A.
    Almost anything will work. The question is how well is it working?
    CruzBay likes this.
  8. grillebilly
    grillebilly Empty Head Subscriber
    16,787
    Fairfax VA
    AC sold me cables with the preamp I bought from them and they were $20 each. I thought he said they make them in house but the package said Hosa Edge microphone cables.
  9. kevzep
    I make my own XLR cables, I use gold plated Neutrik XLR's, and Pro-Co cable, or Belden, Somer or whatever we have in stock.....so much cheaper.
    BobbyBluz and ossidian like this.
  10. techguy0192
    techguy0192 Keep McIntosh amps carbon fiber free! Subscriber
    1,169
    The most import thing to ensure that a cable is quality is solid connectors with proper/quality terminations. Add that to using the appropriate gauge wire and you'll be fine. I've purchased some expensive boutique cables in my day. However, now I stick with the likes of Belden, Carnare, and Mogami.
  11. MACKIE1975
    859
    Make your own cable is the best way and Belden is readily available.
  12. joeinid
    joeinid AK Subscriber Subscriber
    926
    NY
  13. CruzBay
    CruzBay AK Subscriber Subscriber
    748
    Arlington, VA
    PM me your address, and what you need for lengths, and cable count.
    I've squirreled away a bunch of Belden 9451, and many Neutrik XLR's.
    All cable is 'broken in' as are all connectors.
    I'll make the cables personally, using lead free 3% silver solder.
    I'm a broadcast engineer, and have been associated with the high-end audio field for many years.
    And I'm bored.
    I'll make and send you what you need for the price of shipping.
    Mike
    Post a review of the sound, versus anything else you try. If you like something else better; please post that as well. The cables you receive from me are broadcast television standards for many years, and should serve you well as a control group for more experimentation.
    BTW, your cables may be orange; I forgot exactly what I stole.
  14. rocknroll1
    747
    Huntsville, Al
    Thanks Mike, PM comming
  15. exhippy
    1,384
    Wow, Damn good deal there. Take advantage of that!
    By the way, Is that your 99-04 Stang? I have a 03 Cobra (currently down) One of these days I have to crawl back under her and finish the job.
  16. joeinid
    926
    NY
    Ha! you mean borrowed.
  17. Modlin
    Modlin Active Member
    277
    Canada
    bluejeans
  18. slimpikkins
    slimpikkins Super Member
    1,810
    South East PA
    I really like bettercables.com silver serpent. Well made and look nice however I don’t hear any difference between balanced and unbalanced or cheap cables...Get what you can afford while still being able to sleep at night and once in a while take them off and plug them back in again to make a fresh clean connection, that will make any cable sound better..https://bettercables.com/products/silver-serpent-balanced-xlr-audio-interconnect-cable
  19. CruzBay
    748
    Arlington, VA
    It's a Sonic Blue '03 Cobra on the skidpad at Summit point. I think it had a pulley at that point, it's now got a Whipple set for low-boost for road racing (or constabulary avoidance.)
    Also, let's keep this on the down low. I don't need the bottom feeders in this.
    Dc83 likes this.
  20. exhippy
    1,384
    I'm pulleyed, but I dropped my tank last fall to start my return fuel upgrade beginning with my Fore triple hat (probably only running two for now.) Over the winter (and still) can't decide on blower or turbo(s) I'm into drag racing, so I may lean towards turbo. You can see what I ditched years ago in the pic...
    ________________________________________________________________________
    Also, you can just say no.............
    CruzBay and Dc83 like this.
