Greetings -
I'm looking to install some home theater speakers in my basement -
the room doubles as my hi-fi listening area - but I do not intend on using the system for both.
The room is about 9' wide - and I have a screen that takes up about 7 1/2' - so that leaves approx 6-10" on each side of the screen for wall mounted speakers.... OR - some small bookshelfs that could sit atop my main Hi-Fi speakers.
The main HI-FIs are old JBL Soveriengs - which are on stands elevating and pitching them up. Between the jBLs are the tube amps for them - but there is room above them to mount a center speaker right below the screen - (maybe 2 1/2' wide)
The room depth is the entire width of the basement - so 2.5x longer than it is wide.
My reciever is an Anthem MRX710 (couple years old - but still fantatic)
The ceiling is open rafter and only about 7' tall - floor is concrete with a bunch of throw rugs - walls are panel over concrete block.
I had been considering a used set of Sunfire Cinema Ribbons - but they might be overkll in such a small space - maybe not - but they can be wall mounted right next to the screen - and virtually disappear.... or the smaller versions that could effectively sit on my JBLs.
Another thought would be just to have towers sit out in front of the jbls - but i really don't want to keep moving them in and out when I listen to Hifi or a movie.... the bigest issu is that whatever speaker I go with - will literally be right up against the side walls....
Any advice? I am looking at used stuff to try to keep the R/C/L speakers at or under 1k if possible as i also want to replace my sides/backs and subs with something that matches.
Thanks
Thanks
