Please let me know if there are any inconsistencies in this document and I'll give it an edit.
Well I think I have finished the Tice Power Block Service Manual, mostly written to effect repairs from shipping damage which breaks the mounts and pulls the wiring loose.
The Allen sockets are 5/32” and the nuts on the isolation pads are 7/32".
The isolation bushings are ¼”-20 x 3/4” both ends, 1”D x 3/4” height rubber McMasterCarr part number:
https://www.mcmaster.com/9213k15
For transportation the transformer isolation blocks should be removed and replaced with bolts, short at the bottom and long at the top, held with stop nuts onto the transformer legs. Bottom bolts can be ½” or more as they will just bolt the transformer legs to the chassis. Since the ¾” bushing is removed top and bottom the top bolts need to be longer, 2” should work. Using ¼" - 20 bolts would allow use of the same nuts as used on the bushings.
The transformer has 3 connections on each side. These are labeled 1, 2 and 2A on the rear of the unit and labeled 3, 4 and 4A on the meter side.
There are 2-3µF polypropylene capacitors one on the front transformer from terminal 3 to 4 and one on the back of the transformer from terminals 1 to 2.
Wire colors for the Titan add-on go to these terminals :
Rear set
1 Blue
2 Red
2A Black
Front set
3 Brown
4 Yellow
4A Orange
All wires on the Primary switch (selection 1 and 2) are white. All wires on the Secondary switch (selection 3 and 4) are black. Switch positions are being numbered top to bottom for this document.
The power comes in on White, Green and Black
Green goes immediately to the outlet bank ground and these are jumped together for all outlets.
Black goes to the fuse input (side connection) the fuse output (end) goes to terminal 1 on the transformer.
White goes to a 3-wire, wire nut junction with one going to Primary Switch position 2. The other White goes through a varistor (V150LA20A) and then to the fuse input. The fuse has two input connections, the Varistor and the black line input.
Terminal connections on transformer back side by outlets
1-From the fuse and the capacitor
2-Primary Switch Position 3 and capacitor
2A-Primary Switch Position 1
Terminal connections on transformer front side connections
3-Outlets Brass, Capacitor and Meter
4-Secondary Switch Position 1, Lamps and Capacitor
4A-Secondary Switch Position 3 and Lamps
Primary switch
1 Transformer 2A
2 White line input at Wire nut
3 Transformer 2
Secondary switch
1 Transformer 4, Lamps and Capacitor
2 Silver Outlets and Meter through VR+R
3 Transformer 4A and Lamps
Not documented are the resistor and VR in line with the meter.
The lamps are 12V probably 4w.
The fuse is an FNM-15, a dual element fuse.
