Today I was playing some records and noticed a difference in tone from the left speaker (KLH 17) when running the X-101-B. The Left side sounded muffled, almost like the Left Tweeter wasn't working. Right side sounded normal with both drivers working.
CONTROL POSITIONS
Mode = MAG 1
Selector = STEREO
Volume = 2
Balance = Centered
Dimension = MAX
BASS & TREBLE = Centered
Loudness = OFF
Hi/Low Filters = OFF
Tape / LP EQ = TAPE and LP. LP is definately quieter than tape, a little thinner sounding, and with less bass. But no difference in sound left to right. Left is STILL MUFFLED.
So I did some switch work which discounted a speaker malfunction.
Stereo/Mono Selector Set to REV = Muffled sound swapped sides.
Function Set to AUX, FM, and TAPE MONITOR (Aux has cassette, FM is KM60, Tape Mon is TEAC 4010GSL). Muffled sound STOPPED and normal sound resumed.
So muffled sound is only on PHONO So Far.
Tubes: All tubes are NEW Russian tubes from Jim McShane with the exception of the Rectifier. Rectifier is a Mullard GZ34 from my TA-600, branded IEC. I had gotten a Sovtek GZ34/5AR4 for it and had been used for a month, but now a spare. The 12ax7's are 2-12ax7LPS in Phono, 4 Tung-SOL 12ax7 Re-ISSUES in Tone Control and Phase Inverter positions. Output's are Tung-Sol 7591 ReIssues. 12ax7's were Matched in pairs by Jim, and the output's were a matched quad. They seem to like the bias on the 101 # 43v to 44v @ pin 5.
Testing. I tested all tubes on my Philco 9100 (rebranded Hickok 533b) for shorts and gassy tubes, gm and emissions. All Normal and all within 1% of new readings when I got the tubes.
1.) Phono Tubes(V6 & V1) were swapped L to R and R to L. Phono tubes are 12ax7LPS. NO CHANGE on
PHONO
2.) Phono (V6 & V1) were swapped with both the Tone Amps (V7 & V2) and then the Phase inverter tubes (V8 & V3) V2,V3,V7, & V8 are all Tung Sol Re-Issue 12ax7's. These were all matched by Jim McShane.
3.) OUTPUT TUBES(LEFT SIDE V4 & V5) were swapped with (RIGHT SIDE V9 & V10) and put back in original position after testing revealed NO CHANGE!
I then removed and moved the RCA's from MAG 1 to MAG 2/cer. NO CHANGE. This unit had a full recap done to it back in Aug/Sept rightbefore I had the back surgery. This is a new development I noticed today. I'll go thru the Phono stage and check for parts that are touching others, dry joints, and check resistors for bad or out of spec readings. I've got plenty of caps so I can change the caps if needed. I can rebuild the PEC's for PHONO if needed. but with the way it sounds I think it's ok.
If anyone had other ideas, I'd appreciate them.
Thanks
Larry
CONTROL POSITIONS
Mode = MAG 1
Selector = STEREO
Volume = 2
Balance = Centered
Dimension = MAX
Loudness = OFF
PHONO
Thanks
Larry
