AA6U
I'm hoping someone can enlighten me regarding too much bass coming out of the optical output of my Visio TV. I'm using the TV as the HDMI switch for all of my devices (cable box, Roku, FireTV, etc.). I then connect the optical output from the TV to a DAC and then to my McIntosh C32 preamp. The audio from all of the devices has too much bass. I can cut it using an equalizer and reduce 150Hz to make it sound normal, but this is not the best way to process quality audio.
My question is whether the TV us boosting the bass or whether all of devices boost the bass so it is simply being passed through the TV. The DAC is not at fault because it sounds great when used with the optical output of my computer. I was under the impression that the TV's optical output is not processed and is simply the digital signal coming in through the HDMI ports.
If the TV is at fault, I am assuming that using an external HDMI switching box with optical audio output would solve the problem.
Any thoughts?
Any thoughts?
