62vauxhall
Super Member
Ten or more years ago I wound up with this pair of Toshiba headphones with a slide switch to, for lack of a better description, engage/disengage the cross field effect. The very first thing I did upon acquiring these headphones was break the switch. It was stuck and I pushed too hard.
Does anyone know how or if these can be taken apart? When it happened, I drove myself to frustration trying to figure it out then tossed them in a box of miscellaneous for future pondering. They came to mind just now as I was exploring this forum.
This is from memory so bear with me. Would the driver plate twist and lift off the ear cup as I thought it should or do some small rivets need to drilled out?
The objective is to fix/replace the switch and give the headphones a listen experiencing for myself, first hand cross field in all it's splendour.
