Transistor replacement soldering question
Discussion in 'DIY' started by kjello, May 31, 2017.
  1. kjello
    kjello AK Subscriber Subscriber
    500
    Trondheim, Norway
    Hi all gurus or other helpful souls of this beloved forum
    I have a question regarding pcb mounted transistors without heatsink.
    As you can see in this picture there are some heat damage on the board, (amplifier probably took some abuse) my questions are; would it be better to leave the "legs" a bit longer to get more air between the transistor and the board? or is it better to just mount a heatsink down at the board?
    Will the transistor legs "bend" by the heat if leaved too long, and what would be too long?
    And
    This resistor is a 4,7 ohm 1/4 watt, 5% I have 8 of them damaged (pic)
    Now I found some new ones on the www which claims to be the same specs, but they do not have the BLACK stripe, other stripes are the same, Im a bit confused by this.
    Can they still be 4,7 ohms?
    Best regards
    KO
  2. BinaryMike
    BinaryMike Pelagic EE Subscriber
    Transistors mounted without heatsinks must dissipate heat through their leads, so shorter is better in that respect, but they're more likely to get damaged by soldering heat. Pick your poison.
    The black band doesn't signify resistance value. It's meaning might not be standardized at all, but there's bound to be someone here who knows more on that topic.
    kjello likes this.
  3. petehall347
    26,040
    uk.. the middle bit
    i guess we are looking at resistors here not transistors ?
    resistors can be mounted above the board no problem .
    insulator rings on the legs are often used .
    kjello likes this.
  4. Alan0354
    Alan0354 Super Member
    2,735
    Bay Area
    I would mount a small heatsink on the transistor and be done with it.
    This is the first time I see a black band on resistor like this. You might want to go with 1/2W if you have multiple failure with the 1/4W.
    kjello likes this.
  5. avionic
    41,160
    Fort Dodge, Iowa
    Shorted ? Are you measuring in circuit or out of circuit ? Those resistors usually "open" or go real high ohms. 4.7Ω may just look shorted to your meter because they are low resistance.
    redk9258 and kjello like this.
  6. Alan0354
    2,735
    Bay Area
    Agree. They usually open, not shorted. All the ones I burned, they look burned also.....with smell and all. They usually don't die quietly.
    kjello likes this.
  7. kjello
    500
    Trondheim, Norway
    Sorry guys, I mean open resistors of course...
    I should not be writing in my sleep :) I have corrected my questions.
    these bad resistors are in circuit with power transistors that are also broken
    Now the good ones read 4,7 ohms on my meter (the ones from the working amplifier channel)
  8. kjello
    500
    Trondheim, Norway
    Im sorry for my confusing writing
    First question was regarding transistors, second question resistors.
  9. kjello
    500
    Trondheim, Norway
    OK
    So a 1/2 watt will behave like a 1/4 watt in circuit ?
    My guess in this case, is that the resistors was overloaded when the power transistors died.
  10. arts
    arts Super Member
    3,439
    Qc, Canada
    Are you sure those are actually resistors? Might just be a small value inductor....
    kjello likes this.
  11. kjello
    500
    Trondheim, Norway
    This is from the schematics
    Im afraid I may not know the difference
  12. kjello
    500
    Trondheim, Norway
    They are reading Mega ohms in- and out of circuit.
  13. arts
    arts Super Member
    3,439
    Qc, Canada
    Well,the schematic indicates a 4.7 ohm resistor. I'm thinking the ''F'' indicates either fusible or flameproof.
    EDIT:
    Also,the exclamation point indicates a component with a ''safety'' requirement. If you are measuring very high resistance (megohms) then these have failed under overload.
    kjello likes this.
  14. Alan0354
    2,735
    Bay Area
    If it is a fusable resistor, you need to find out why it burn.
    You have the schematic, post the whole thing!!! With the schematic, we can tell you a lot better what you should and should not do.
    Indicate what transistor on the schematic that is getting too hot.
    kjello likes this.
  15. kjello
    500
    Trondheim, Norway
    Link to schematic: https://www.hifiengine.com/manual_library/nad/218-thx.shtml
    So far I found:
    Q326(C3788), Q318(A1478) shorted
    Q338(D1975), Q342(D1975), Q344(B1317) shorted
    Q332((A1837) shorted
    R358, R360, R366, R368, R374, R376, R382, R384 all 4R7F reading mega ohms out of circuit.
    R370 3W 0,22 ohm cement resistor reading mega ohms out of circuit
    All this in the right channel power amplifier board
    According to previous owner, damage probably caused by shorted speaker output.
  16. Alan0354
    2,735
    Bay Area
    I need to login, I don't have account, can you just post the schematic?
    kjello likes this.
  17. avionic
    41,160
    Fort Dodge, Iowa
    So there not shorted. They are for all practical purposes "open". A short would be like zero Ω's.
    1/4 watt most likely.
    kjello likes this.
  18. avionic
    41,160
    Fort Dodge, Iowa
    It only takes 5 min. or less and is free.:idea:
  19. kjello
    500
    Trondheim, Norway
    Is it possible to post a PDF file?
  20. Bob
    Bob AK Subscriber Subscriber
    1,927
    West coast
    black is usually no tolerance and sometimes 20%. lift one leg (or remove) to measure it. if it's
    still inside the range then it's OK.
    Hyperion and kjello like this.
