Gobstopper
Hi Folks,
I posted last week asking about filter caps for this unit, and I wanted to follow up with some issues I've discovered. For some background, I swapped out all the electrolytic caps, diodes and transistors on the power supply and electrolytics plus a couple of the transistors on the protection circuit. I swapped out all electrolytics and transistors(other than those mounted to heat sink) on Power Amp and all the electrolytics, tantalums and transistors on Control Amp.Same for Equalizer board. I also tried to deoxit and faderlube the pots and switches. I'm not sure I got any clear into the lever switches though since hard to access and didn't see any obvious openings. Tried rotating plug 180 degrees to no effect All testing done with headphones(various sets that work well fine outside of this amp)
Issue:
Constant steady hum in left channel, does not respond to volume or balance controls.
With pre/main jumpers in: Hum in left, rustling/static in right(not consistent)
Removing pre/main jumpers: Hum in left, quiet in right
While jumpers were removed, I plugged in audio source into Main-In, and was able to hear music in both channels, but hum was quite loud(in left channel) when music stopped.
I took some voltages around the relay(based on wiring diagram from the service manual) and
found the following readings:
Pin DC AC
9 50 mv .007 V
10 136 mv .15 V
This case had rustling/static in right channel
repeated 10 mins later after leaving off for awhile and doing some other things
Pin DC AC
9 22 mv .04V
10 66 mv .007V
This case no rustling/static in right channel.
For the power amp:
Pin DC AC
2(out 1) 69.3 mV .03V
17(out 2) 25.2mv .007
(the rest of the voltages at the pins were within 10% of values listed in SM)
I'm supposing the rustling/static in right channel is due to the control amp or dirty pot/switch although the transistors and caps were changed.
The hum in power amp I'm not entirely sure about. The left channel transistors mounted to heat sink? Bias/offset issue? I haven't tried setting bias and offset since I was a bit intimidated with removing the wire wrap pins from board as required in SM, but if that is recommended as first step I'll do that. Could it be something else entirely?
Any suggestions on what else to check?
Thanks!
Issue:
Pin DC AC
9 50 mv .007 V
10 136 mv .15 V
Pin DC AC
9 22 mv .04V
10 66 mv .007V
For the power amp:
Pin DC AC
Thanks!
