TU 919 Accessing the tuning capacitor
Discussion in 'Tuners' started by Helios, May 4, 2017.
  1. Helios
    Helios Active Member
    175
    Quebec City
    My tuner has begun to exhibit some scratching sounds when I change stations, so I intend to clean the contacts. Problem is that it is enclosed in a shield. The top of the shield suggests that a part can be removed, but that part is soldered via two tabs to a board. For those who have done that before, is it safe just to desolder the tabs ? or ... ?
    [​IMG] [​IMG] [​IMG]
  2. amptramp
    amptramp Active Member
    367
    Mississauga Ontario Canada
    I have desoldered tabs before but it works better with tube sets with the tabs going to a chassis. You have to be more careful if the tabs are soldered to a circuit board but from your picture is looks like it is mounted to the chassis.
  3. Hyperion
    41,374
    Hertfordshire, UK
    I hope you realise how sensitive the tuning capacitor is, and the likelihood that the tuner will require realignment after this work is a very definite possibility.
  4. Punker X
    Punker X AK Subscriber Subscriber
    3,868
    Panic in Detroit
    Yes safe to un-solder the tabs, and yes will require alignment after cleaning. This front-end is used in a couple different tuners and all are prone to scratchiness. Sometimes requires a burnishing tool on the ground tabs.
