Tube friendly speakers question
Discussion in 'Speakers' started by grindfix, Jul 11, 2018.
  1. grindfix
    grindfix Full time hobby Subscriber
    729
    New Albany, OH
    I know most vintage Klipsch speakers are great with tubes. I own a set of original Cornwalls and they sound amazing but they are also quite sensitive. I'm curious if there are less efficient tube friendly speakers out there, both vintage or current production?
    Thanks
  2. darkblue94
    darkblue94 It wasn't me.
    9,162
    The Pacific Northwest
    The answer is...yes there are. :)
  3. valvenator
    valvenator curious bystander, serious procrastinator
    Thought I'd give you a little bump.
    As usual, darkblue94 has the definitive answer:p
    Honestly, I think this is the first time I've ever seen someone looking for less sensitive less efficient speakers for a tube amp.
    darkblue94 likes this.
  4. grindfix
    729
    New Albany, OH
    I have homebuilt 23wpc tube amp that is not completely quiet. Still trying to get that figured out. Hum is barely noticeable with some 12'' JVC floor speakers I have for testing. Much more noticeable with Cornwalls. I doubt that with efficiency of Cornwalls this amp will ever run even 20% or even less of it's power. I'm thinking that less efficient tube friendly speakers might be better fit? I wouldn't know until I try
  5. Drugolf
    4,792
    Boise
    Right before I sold them, I hooked up some JBL 4313b to my Dynaco ST70 tube amp at they sounded very good.
  6. stish
    stish AK Subscriber Subscriber
    682
    Huntsville AL
    It all depends on the volume of your space, type of music, and listening level. I once had success in a near field set up with 93db sensitivity speakers and a 2 wpc SET amp. However, my current listening room would kill that sweet little amp. With 23 watts per side, I suspect you have more options than you think.
    Leland47 and darkblue94 like this.
  7. Harvestor
    Harvestor Super Member
    a pair of OHM model I (eye)
    Or model B2
    Or model H
    Leland47 likes this.
  8. gdmoore28
    gdmoore28 Super Member
    2,835
    Central Arkansas
    The reason the hum is less noticeable on the JVC speakers is that they are less able to produce low frequencies than the Cornwalls. The hum is still there, just not reproduced. Of course, that's what you said, isn't it?
    I'm not an electronics guy, be forewarned, but I'll bet you are hearing the typical 60Hz hum that is usually indicative of ground problems. Did you build your amp from a kit? Repurpose an older amp?
    Surely some of the electronics guys will come along to suggest how you correct the hum in the amp. That's where your problem is - not in your speakers. I'd suggest reposting with a new title to that effect in the DIY forums - "Amplifier Hum Problem," or something to that effect.
    Good luck.
    GeeDeeEmm
  9. Chrisxo55441
    Chrisxo55441 AK Subscriber Subscriber
    2,574
    Twin Cities Minnesota
    I like my Tannoy Cheviots better than my Forte's with my tube gear.
    Drugolf likes this.
  10. Arthur Smith
    Arthur Smith Well-Known Member
    916
    How about any of the classic, vintage acoustic suspension speakers like the AR's, KLH's, or Advent's?
    Harvestor likes this.
  11. Drugolf
    4,792
    Boise
    Oh, and my Altec Santiagos are fantastic wit tubes, but of course huge.
  12. grindfix
    729
    New Albany, OH
    I'm not trying to find speakers to eliminate my hum issue. I will have to sort it out either way. I just think that in my smallish listening area of about 12'x12' Cornwall's efficiency will barely let amplifier to operate above idle.
    I did not like Original Advents with Fisher 400 which is similar schematic and output power.
  13. 6L6PPP
    6L6PPP New Member
    6
    Bozak's sound fantastic with tubes .... 302b, B-313, B-401 with sub, B-301 and B-201 with sub.
    Frazier Mk 4's, EV Sentry 2 or 2A .... EPI M-201/ EPI M-202 if you have a 4 ohm tap on your amp.
    Most of my tube amps (home made) are around 20-25 watts which is plenty with the Bozak's, Fraziers or EV's. Speakerlab model 4 and model 6 work great if you have 30-35 tube watts.
  14. LexDM3
    LexDM3 AK Subscriber Subscriber
    1,773
    Arlington, MA
    KLH Sixes sound very nice with tubes.
    Arthur Smith and Tim D like this.
  15. bowtie427ss
    bowtie427ss arigato gozaimashita
    17,434
    Land of Milk & Honey Boo Boo
    I doubt the Cornwalls have any bass extension advantage over the JVC's. The reason for the difference is the difference in sensitivity, probably close to 10 db between the two which means he's getting almost 10db less hum with the JVC's.
    But i do agree with you GDM, he needs to deal with the hum at it's source by chasing it down in his amp best he can. Sometimes it's as simple as re-routing small signal wires, or as you mentioned grounding issues. If i could think of something i miss about tubes, i'd mention it here. ;)
    gdmoore28 likes this.
  16. 911s55
    911s55 AK Subscriber Subscriber
    599
    Puget Sound
    I'll second the JBL bookshelf suggestion, I ran some 4412 monitors with a Scott 299c, very nice and plenty loud too.
