Tube Help - 6AR5
Discussion in 'Tube Audio' started by MRL_Audio, Jul 4, 2018.
  1. MRL_Audio
    MRL_Audio AK Subscriber Subscriber
    6,376
    St. Chuck, MO
    I have a Hickok 800 tube tester. I also have a 6AR5 tube I need to test. The manual and spinning tube lineup does not include this tube in the mix. Tube came from a vintage Akai M8 reel to reel. Appreciate any guidance on the proper settings for this tube in this tester. Thanks for looking.
  2. dcgillespie
    9,935
    Ball Ground, GA
    MRL -- The tube has a pin out equal to that of a 6AQ5 -- except that the 6AQ5 uses BOTH pins 1 and 7 for a G1 connection, where as the 6AR5 only uses pin 1 for G1, with pin 7 showing N/C. And, the characteristics of the 6AR5 are identical to that of a 6K6GT. Therefore, if you can arrange the socket terminals to pin-out for a 6AQ5, but set the tester up for the characteristics of a 6K6, you'll be good to go.
    I hope this helps!
    Dave
    GordonW likes this.
  3. tubeactive
    tubeactive AK Subscriber Subscriber
    326
    NJ
    Dave, You, sir, are always helpful. You are The Man !
