rockarolla
Yes the dummy that I am knocked the tuner string off the pulleys when opening the unit. Can anyone guild me with proper placement? The string is not broken.
Thanks,
JP
Thanks,
JP
Might get lucky and just be a spring slipped out of position on that switch.I checked today, and yes you nailed it. I have also contacted Dave for some lamps. I reviewed the archives for cleaning. It's coming along. I have been cleaning throughout the day. all switches and knobs are quiet except:
Power off I hear a pop.
The FM muting / ots switch does no lock into place when pushed.
Thanks,
JP
Aren't re-stringing dial cords lots of fun..
I just finished re-stringing a Sansui 5000x..Believe me.A yamaha is easier..
What are you using to check it with? Only a TT gets plugged into the phono-Anything else risks damage to the front end of the phono EQ amp.:yesid you try swapping the left and right phono inputs around ,to eliminate the possibility that the source is the problem?The next issue is I checked the phono section and it appears that the right channel is not working
Try cleaning/recleaning the "Input select SW." and the "Phono Select SW."
