technut
ACK!
I have a pioneer tx-7800 that has been working fine for a few years now but all of the sudden it's acting up!
It has developed a problem in the lower 1/3 of the FM tuning range, lets say 88mhz to 93mhz, it will cut in and out even with a strong signal showing on the meter.
It almost sounds like a poor connection, or like the muting circut is going active when it should not. When tuning in this range there is no background hiss between stations and only when you have a station locked in and you then work the dial back and forth a little will it suudenly give audio output.
Once it is working, it continues to put out sound with no problem, and still sounds fine. So my question is: does the tuner gang itself have something to do with this or is it an alignment problem?
What is the best way to clean a tuner gang? I have heard other members say that contact cleaner is not a good idea, does anyone have a personal favorite that is safe to use?
