Coastsider
Curmudgeon
I have three pair of Infinitesimals, 0.1's, 0.2's and 0.3's (sometimes referred to as III's) and a spare pair of 5" Watkins woofers with black poly cones that I stumbled upon some years back in a mis-identified eBay listing. I am contemplating installing the spare Watkins into the 0.3's to create a new variant - maybe a 0.2.5 - but am not sure how to proceed with the modification of the crossover. Since the 0.2 crossover is closest to the one in the 0.3 with the two slide switches present, I figured that would be the best model to use but would like to solicit opinions as to specifics in adding the Watkins woofer's secondary VC to the mix. I know it would just be easier to find some loose 0.2 crossovers but what do you figure the odds are of that ever happening?
Here are the crossover schematics for both:
http://www.infinity-classics.de/technik/manuals/Infinitesimal_0.2_technical_sheet.pdf
http://www.infinity-classics.de/technik/manuals/Infinitesimal_0.3_technical_sheet.pdf
Ignoring the spec sheet for the 0.3 which say it has a DVC woofer which of course it doesn't, the schematic shows a conventional woofer and so should otherwise be correct. I am going to pull the woofer on one of my 0.3's this afternoon to check the crossover against the schematic.
Any and all suggestions and opinions on this potential project would be appreciated.
