Turntable Dust Cover: Up Or Down
Discussion in 'AK Polls' started by Nightwisher, Jul 6, 2016.
Turntable Dust Cover Position?
  1. Up
  2. Down
  3. It Depends
  4. Don't Have One
Results are only viewable after voting.
  1. Nightwisher
    Nightwisher Farer In The Goldilocks Zone Subscriber
    3,316
    South Carolina
    A little poll. Who uses their turntable with the dust cover up, down, does it depend, or do you not have one?
    Personally, I use mine up, because most of my vinyl listening is while I'm archiving them to my computer. If I listen to a record just to listen to it, I'm more likely to have the cover down. So that puts me in the "It Depends" category.
  2. dcmfan
    dcmfan AK Subscriber Subscriber
    3,880
    Welcome 2 Missouri
    We've got dysfunctional dogs (aka "cats") so it's cover down for me!
    zenarrrow likes this.
  3. rebellovw
    rebellovw Super Member
    3,092
    Prescott, AZ
    Off on both tables.
  4. ETLS
    ETLS metacarpophalangealcranium Subscriber
    15,904
    Texas
  5. easycraig
    easycraig Super Member
    1,437
    up when its playing..... down when its turned off.
  6. smccrary
    smccrary Low-Budget Collector
    618
    Hilliard, Ohio
    Down when using the Yamaha. Off when using the Elac or Harman .
  7. ETLS
    15,904
    Texas
    I had a dual purpose dustcover back in the 70's.
    Slave Driver likes this.
  8. holyman772
    holyman772 Super Member
    1,082
    Utica, NY
    This. Call me a nut job but I think my records sound better with the cover up.
    91r100gs and easycraig like this.
  9. gizzyman47
    gizzyman47 Super Member
    1,221
    utah
    I noticed I was getting some distortion while playing an album the other day. I had the cover down and the volume rather high. I cleaned the cart thinking that was the issue but it turned out to be resonances from having the lid closed.
    Kieran Jones likes this.
  10. jcamero
    jcamero Who are you people anyway? Subscriber
    4,200
    The Dairy State
    My 1229q dust cover has no hinges, so off. My other turntables, (with hinges) up, unless last song of album prior to turning my system off, then down.
  11. woofmytweets
    woofmytweets Super Member
    1,560
    Toronto, Canada
    down - no choice the linear tracker won't play with the lid up.
    *hides from rotten tomato barrage
    DrummerGeek and easycraig like this.
  12. Chrisxo55441
    Chrisxo55441 AK Subscriber Subscriber
    2,534
    Twin Cities Minnesota
    Up or off probably more because im lazy then i think it makes a difference, one less thing to do when i flip or change the LP
  13. for_p1
    for_p1 Addicted Member
    5,523
    Northern TX
    Cover helps isolate tonearm from acoustic waves from speaker. But cover should have multiple points of contact with table, otherwise it starts ringing.
  14. Cactus Bob
    Cactus Bob Desert Rat Subscriber
    26,805
    Way Out West!
    Off
    Djcoolray likes this.
  15. peerson
    peerson Well-Known Member
    926
    Kansas City area
    My pioneer, up when playing. My marantz, off
  16. Ghost_Inside
    Ghost_Inside New Member
    6
    Frankfurt, Germany
    I got two 1210s hooked up to a mixer. So obviously it´s up when I’m mixing records and down when I’m just listening. I see some interesting comments about resonances when it´s down. I guess that´s when you´re listening at high volume. I´ll need to check that out.
  17. savatage1973
    6,663
    NW Pennsylvania snow belt
    Up while playing, down when just sitting--but I have a big dog that can put hair anywhere (hence the down while not in use), and my table is in a fairly well isolated cabinet, so when in use, it is not subject to resonance issues, so the cover stays up.
  18. Splatter Pak
    Splatter Pak High-End Scrounger
    3,933
    Independence, MO
    I take the thing OFF - no hinges.
  19. asilker
    asilker Bible Reader Subscriber
    2,701
    Chicago IL
    No dust cover on the modified 1200.
    If I had one I would use it with a pillow in top.
  20. Celt
    Celt Peanut Head Staff Member Super Mod
    38,009
    Paragould, Arkansas
    Don't have one....don't want one. It's an optional thing with the SOTA. Dust isn't a problem here.
    asilker likes this.
