Roboturner91
Super Member
Both early 90s Yamahas - RX-V850 and RX-770. Both displayed the same behavior - turning off about 2-3 seconds after being turned on.
To make a short story long, I recently changed the rooms my house (old house, built in 1930s). Put my two sons in the same bedroom, moved my home office into the now-empty younger kid's bedroom.
Set up my stereo, enjoyed it a couple days, then poof. Receiver (RX-V850) went dead. I brought it to a repair shop, plugged my backup receiver (RX-770) into the system. Same thing. Worked for a couple days, then poof. It's dead now too. Now I'm suspicious it's the power outlet so I checked that out.
The outlet I had plugged both these receivers into reads hot/neutral reversed on my outlet tester. I plugged the second receiver into a known good outlet and it still doesn't work. I don't have the first one since I brought it to the shop but I suspect that would be the case for it as well.
Is it safe to say this outlet killed my receivers? I didn't think reversed polarity wiring was all that dangerous. I'm going to replace the outlet and hopefully my receiver can be fixed.
