contadotempo
New Member
Hello, I've been a reader for a while but only recently decided to register.
I have acquired a Pioneer TX-710 that seems to have a faulty auto-tunning function on FM mode. Whenever the auto-tune function starts, by either pressing UP or DOWN, the tuner cycles through the whole FM spectrum and never seems to stop, even when the radio signal is detected as maximum (indicated by all the signal strength LEDs lighting up). On AM mode it seems to work just fine, stopping as soon as it finds a station with a good signal.
First thing I did was to acquire the circuit schematics: http://www.kallhovde.com/pioneer/tx-710l-om.pdf. Then I started fault-hunting. At first I suspected the LC7207 (Q13) "voltage synthesizer" (found a datasheet in Japanese http://pdf.datasheetcatalog.com/datasheets/700/501893_DS.pdf and also a service manual for a different tuner using the same IC, http://www.creapromedia.fr/lesdocs/sony/strs5l.pdf, page 7) since some voltages were a bit off according to the schematics. However, the previous owner then mentioned he replaced this IC with a new one, behavior was the same.
Then I noticed that the FM/IF System IC, the PA3001-A (Q7) was giving me 13V on PIN 7, which is described by the datasheet (http://nice.kaze.com/PA3001A.pdf) as "Tuning meter output", and should have 5.6V +/- 1.5V. I followed it through the circuit and found the PC4558C DUAL OP AMP (http://www.alldatasheet.net/datasheet-pdf/pdf/6768/NEC/UPC4558C.html) (Q12), which seems to be comparing the signal coming from the PA3001-A, to build the FM S-Curve (I might be wrong here) between PIN 2 and 3 of this OP AMP, outputting the result at PIN 1. The schematics say that PIN 1 should have a voltage of 4.7V. I get 25V (almost the positive supply voltage on PIN 8). I thought it could be this IC that broke down/short-circuited. I replaced it but got the same results. I cannot pinpoint why I'm getting such a higher voltage in these pins. What could it be?
This seemed relevant to the auto-tunning problem because PIN 1 of this OP AMP feeds PIN 13 (named S-Curve by the schematics) of the LC7207 "voltage synthesizer". I also asked the previous owner about the PA3001-A, he replaced it as well, but to no avail.
The previous owner of the tuner did tell me he accidentally short-circuited the darlington of the power supply (Q20), which in turn destroyed the 14V Zener diode attached to its base (D34). He replaced the darlington and the diode with a 15V Zener diode. Consequently, it raised the voltage a bit in some components. I did dismiss this since he also said the auto-tunning problem was already there before he got his hands on it. And also because the voltage on every terminal of the ribbon cable was approximately correct according to the schematics. I contacted with fellow user r_electronic, who made the thread http://audiokarma.org/forums/index.php?threads/pioneer-tx-710-problems.547087/, and he mentioned it could be a faulty power supply/insufficient voltage. I'm inclined to recheck it, should I?
I have uploaded a few photos as-well
Thanks in advance for any tips.
