The adj procedure is in the manual but you need special equipment for that.
I do not know this unit very well, but if it is like others, there is a tension spring in the tuning wheel attached to the var cap. Problem can be you unravel the string which is a PITA to put back. You can make a note of the dial string the way it is put on if you mess it up. You can put some tape around the tuning wheel so that the string does not unravel form the wheel, The pointer is attached to the string through some stranin reliefs, the string has to be taken off the point to move in the direction to re-cal it against the dial. None of this is easy, it takes some practice.
