unbalanced to balanced conversion?
Discussion in 'General Audio Discussion' started by HiFiThor, Mar 5, 2017.
  1. HiFiThor
    HiFiThor Active Member
    211
    My Pioneer Spec 1 preamp and Spec 2 power amp use unbalanced RCA connectors to interconnect. In my new listening room I would like to separate them by about 30 feet so I think balanced is the way to go. Are there converters for this? I have seen some discussion on baluns but aren't these passive devices? Does balanced need an actual active circuit for the connection in order to take advantage of the benefits? Anyone have a procedure or plan to add balanced in/outputs to an amp set up that only uses RCA?
  2. xero-D-hero
    xero-D-hero Super Member
    2,452
    There are quite a few co.s that make these,but the thing is to use it the way you wanna use it you'll need one of 'em @ both ends.
    Usually they are used to convert a piece (or more) of unbalanced gear (RCA -or- 1/4") gear to balanced gear (usually XLR) so only one is needed most times.
    Also keep in mind that sometimes a given box only converts one way -or- the other depending on which is needed,other boxess can convert both ways.
    Rolls & ART both make boxes like this.
    IIRC the ART cleanbox pro is one of them,no doubt there are others.
    These are mostly used by folks in the music recording industry so you'll wanna check sites for gear oriented towards that field.
    HTH
    Bret P.
  3. whoaru99
    whoaru99 Epic Member
    40,917
    LoTL
    I would get some decent RCA cables. It will be just fine for only 30ft.
    sqlsavior and JoeESP9 like this.
  4. twiiii
    twiiii Addicted Member
    6,559
    west Texas
    What you have to watch out for is forming a ground loop by using two different AC wall receptacles at different ground potentials. As others have said 30 ft shouldn't be an issue if the Pioneer pre-amp has a low output impedance.
    woodj and sqlsavior like this.
  5. xero-D-hero
    2,452
    Though I tend agree that a quality unbalanced RCA cable should be ok @ that length,I try to just answer questions as they're asked for the sake of brevity.
    FWIW
    Bret P.
  6. ehoove
    ehoove Old & New - Carpe Diem Staff Member Super Mod Subscriber
    18,383
    Mid-Maryland
    I run balanced XLR from my preamp to my crossovers (26ft) only way to go at length. IMHO
    Regards,
    Jim
    botrytis likes this.
  7. whoaru99
    40,917
    LoTL
    Sure, if the gear has balanced.
    Bill Ferris likes this.
  8. xero-D-hero
    2,452
    Nah were cool,I just felt I should add that disclaimer for the sake explaining my comments better.
    :cool:
    Bret P.
  9. Bill Ferris
    Bill Ferris Super Member
    1,936
    NE. FL.
    Hi HiFiThor, I don`t know if you resolved your remote amp/preamp setup as posted a little more than a month ago as I just stumbled across your post.. I had the same kind of situation in 1995.. What I tried first was to run 40 ft. custom made Monster Cable interconnects between the remote amp and preamp.. It worked but also had ground loop hum and switching noise from light/ceiling fan switches, ect. because of the preamp was plugged into one power circuit & and the power amp in another.. I tried to isolate with Cat 5 cable & baluns later on and also line level RCA to RCA isolators, but neither passed any signal because of the very low impedance output of the preamp was basically shorting out the galvanic isolation transformers of either type of method.. What I ended up doing was to run a small 16 ga. extension cord from the power amps 120 volt power source to the preamp and its low powered connected devices(tuner, CD player) so all connected audio gear was at, or nearly at the same ground potential, which greatly reduced the ground hum noise.. Anyway, FWIW. that worked well for me until I totally reworked the whole setup differently years later.. I don`t know of any other HiFi quality "safe" ground loop prevention/breaking methods, though others on this site might.. The" common ground power source" feed setup that I described above worked every time for me when I setup and ran PA`s for rock bands with all the power amps on stage and the mixer, eq`s, crossovers, & effects were out in the audience fifty or more feet away, even when there was a closer power outlet nearer to the sound board in some cases.. Just my .02 worth. Good luck with whatever method you end up using & enjoy the music Sir.. Regards, OKB
  10. HiFiThor
    211
    Thank you for your input! I did not think about ground loops in the AC power distribution in my home. This is very relevant because I am going to build a new home and now I can specify a separate dedicated 30 amp service to my listening room. Great advice from you.
    I bought a couple of unbal/bal converter boxes which are powered and allow for long low impedance balanced connection. I was looking at them and started to think about what exactly is going on with this. My Spec-1 is limited to a max of a 2 volt output, which doesn't seem much to work with. I have not looked into it but I am thinking that preamps that have balanced outputs can actually start with a high amount of output signal, more than 2 volts. The Spec-2 power amp has input level controls to adjust for connections to preamps like this. I just wonder if I am making something out of nothing. Trouble is I cannot actually hook this stuff up and test it all until I get my home built.
  11. lini
    lini just me...
    5,954
    Munich, Bavaria
    B_F: Oh, there also would be several other solutions, both wired and wireless. For example, one could also go: output -> ADC -> optical SPDIF cable -> DAC -> input. However, many of these other solutions would seem likely to sound at least a bit different compared to the pre- and power-amp directly hooked together as intended.
    Greetings from Munich!
    Manfred / lini
  12. Bill Ferris
    1,936
    NE. FL.
    HiFiThor, I don`t think you need to concern yourself with the 2 volt Spec 1 preamp unbalanced output level being a problem.. It has not ever been for all my friends & my self`s stereo setups of varying complexities.. While more modern home stereo gear is showing up these days with balanced inputs and outputs which can have decided benefits especially with difficult and complex setups and it`s higher signal output capability can be helpful in some situations.. Granted, a balanced line level connection setup is the best, if all the connected gear provides for it, it`s what the pros use.. I guess I`m the impatient type.. I would in your situation temporarily set up your setup as close as it could be to the way it with be in your new house using the active bal/unbal converter boxes connected up and with the preamp in one room and the power amp in another with the cables connected to see if this scheme has any chance of working properly.. I have never been married, so my whole house is a Man Cave and I can rig up & test out rigs without concern about offending or pissing off a wife or having children stumbling across the temporarily strung wires across the floors and have set up complex concept test rigs("feasibility study") many times over the years before committing to them.. But that`s my situation and yours might not allow for the test hookup.. Anyway Sir. I`m glad to have been of some help to you.. Good luck and take care.. Regards, OKB :music:
  13. whoaru99
    40,917
    LoTL
    Personally, I think you have the boxes unnecessarily. Decent RCA cables are nearly a sure bet to work, and the converter boxes do nothing to alleviate ground loop and may even cause more problems if they, themselves are powered.
    The max output of your Spec 1 is NOT 2V. That is the nominal output. MAX output is 7V. Of course, what comes out is proportional to the signal level going into the pre amp from the sources and the volume control position.
    While pre amps having balanced outputs may in fact have higher output simply because it's a differential voltage, a balanced input normally also requires more input so overall output/input ratio is typically same/similar.
    Note, however, regardless if unbalanced or balanced, they all start at 0 output with the volume all the way down, and go up from there as you increase the volume setting.
    Your Spec 2 amp requires 2V input for full rated output. If you don't necessarily need full rated output then you don't need to have capability to supply 2V to the amp. Again, bear in mind this is a variable signal from the pre amp to the amp. 0 with the pre amp turned all the way down, up to whatever it takes to get the volume you want within the limits of the amp. For typical listening the signal level from the preamp to the power amp will be only some millivolts. For example, roughly 125mV (0.125V) from the pre amp will cause about 1 watt per channel of power from the amp to the speakers.
  14. Bill Ferris
    1,936
    NE. FL.
    I`m sure there are Manfred, but I personally prefer the most direct method, if possible. When, in 2009, I had five rooms( + a 4K living room projector) of my house wired with 5 circuits of high quality Belden Mediatwist Cat 6 + cable with the signal specific baluns at the source(my living room`s rack) and at each room. I had (1) 2 channel audio(upgradable to 4 channel), (1) SVGA(hd15) for the rack`s lap-top feed, (1) 1080p HDMI(upgradeable to 4K), (1) RGB, & (1)S-Video + composite, all my previous hum ground loops, picture noise, ect. went away.. I have in all those rooms a LED flat screen and either a receiver, integrated preamp/power amp, or separate components, so each room has local selection and level control with wireless IR repeaters to control the living room`s rack(AKA the octopus head) BluRay player, selection of audio sources, security cameras, laser disc player, ect. All with excellent sound and picture.. I really don`t like to trust wireless for anything but WiFi and a handful of wireless added on FH/SS security cameras. I spent nearly a year thinking about how I wanted to do this before paying my A/V dealer to run all the Cat cable feeds and to be performance + bandwidth certified by a separate contractor.. Just my old school way of hard wiring doing things for absolute reliability.. Thanks for your suggestions and comments Manfred.. Take care Sir. Regards, OKB
  15. HiFiThor
    211
    One of the design considerations of my new home was that I have a dedicated space to fully exploit my HiFi habit. A big space. I have been compromising my love of of Stereo for far too long. When I drop the needle on Rush or Beethoven you are going to know it. I do not expect to hear "Turn it down" or "The kids are asleep" or "My ears are bleeding!" I live in the middle of 5 acres in a rural setting. If I blow up something I'll just fix it or get something stronger.
  16. Bill Ferris
    1,936
    NE. FL.
    Yes Sir. Excellent mindset HiFiThor !! Kudos Sir. :beerchug: My sonic Brother of another mother. :thumbsup: Take care and good luck with your sonic pursuit.. :music: Warm regards, OKB
  17. aabottom
    aabottom Swing
    1,384
  18. triode17
    triode17 Super Member
    1,375
    Yes but it should be low capacitance cable. I ran about 30 feet from one room to another and ended up with a high freq. oscillation. So, I built an active impedance buffer to solve the problem.
  19. bimasta
    bimasta Super Member
    2,728
    Old thread, may be irrelevant now, but...
    I agree with Whoaru, but would say "decent RCA cables", on a 30-ft run, should be at least double-shielded and one of the shields should be continuous foil. Gaps in the normal braid let RFI leak in, like holes in a ship's hull — not an issue with the normal 3-ft run, but very loud when multiplied times 10. I used Mogami's best-quality interconnect cable for 26-ft runs and the hum was intolerable. Switched to cable with a foil shield under the braid and it was silent.
    TV / Internet cable companies install miles of cable, highly susceptible to outside interference: such a length is an antenna. They use cable with continuous foil shielding, plus an additional four layers of braided shield around it.
    sdw54 likes this.
  20. KentTeffeteller
    26,157
    Athens, TN
    And they also have distribution amplifiers so they can run that cable those distances.
